Old 04-07-2007, 12:47 PM   #1
boatpuller
boatpuller's Avatar
stiff gas pedal
here's a stupid little one that bugs me...............the gas pedal is stiffer than it should be,always has been sinced i owned it.so,i replaced the cable with a new one,routed with no kink,disassembled entire foot pedal setup ,firewall mount greased.got a new carb,not for that reason.and the damn thing still stiff,not bad after your going.must be in that pedal assembly somehow.i'm about ready to blow a 100 bucks on some aftermarket lokar hot rod pedal setup or something.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 04-07-2007, 12:55 PM   #2
kevinr1970
Re: stiff gas pedal
I am sure you already tried this but didn't mention it, but how about a lighter return spring on the carb?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 04-07-2007, 02:06 PM   #3
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: stiff gas pedal
agree i think it sound like a spring.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 04-09-2007, 11:52 AM   #4
boatpuller
boatpuller's Avatar
Re: stiff gas pedal
you know in all the excitement of the new carb install,i just stuck the old spring on there.so i've been trying a few i had laying around and it did help.so,i went to lowe's and got a wimpy looking one, and it feels alot better than parts store carb springs.there still something there that i don't like,i'll find it.i'm the kinda guy that the stuff bug's me enough i won;t give up till it's right.end up spending alot of time on stupid little stuff. oh well.
Old 04-09-2007, 01:49 PM   #5
kevinr1970
Re: stiff gas pedal
Originally Posted by boatpuller View Post
...end up spending alot of time on stupid little stuff. oh well.
Unfortuneatly for me a lot of money too!?!
I was just thinking about an '85 K5 I used to own.
My sister was buying it from me - she had a situation so I more or less gave it to her and she was fixing things on it as she drove it.
The carb was having issues so her then boyfriend replaced it with an Edelbrock. This involved using a spacer under the carb.
The driveline broke and ended up cracking the case of the transfer case so she gave it back to me.
After getting it back on the road I noticed that when giving it gas it was real hard to a point then it got easy. This was real annoying especially since it was a manual tranny - you would end up flooring it when it got over the "hump".
The spacer was because of the EGR valve. I removed the EGR valve and was able to remove the spacer. The throtle was smooth as silk then.
Short story log, like was said before check the angle of the throtly cable. It made a huge difference on that K5.
2000 Tahoe Limited
Old 04-08-2007, 03:48 AM   #6
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Re: stiff gas pedal
I'm not sure what kind of brackets you're using for your cables near the carb, but with mine, the bracket can be turned side to side by loosening the nut that holds it down. If I turn it to the right, it loosens the cable, and to the left will tighten it and make it stiff. Sounds like you just need to adjust your cables...
xtreme80 is offline   Reply With Quote
Old 04-08-2007, 04:55 AM   #7
ureckme
ureckmefixit2@cox.net
Re: stiff gas pedal
If the cable is to low on the carb linkage it will be hard to push. See if you can move it up.
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
Old 04-09-2007, 09:53 AM   #8
neverfinished
Re: stiff gas pedal
I have the same problem but it hasn't bugged me enough to hunt down the source. I guess I know what not to try now.
neverfinished is offline   Reply With Quote
