Old 04-07-2007, 02:17 PM   #1
corkscrew
My motor wo'nt turn over...
I accidentally let the battery die and when i charged it up the crank won't even turn over. I never touched anything or modifyed anything...what do you think it could be? Could it be maybe a wire on the started got disconnected? what other connections could i check out?? thanks guys
corkscrew is offline   Reply With Quote
Old 04-07-2007, 02:59 PM   #2
jhow66
jhow66's Avatar
Re: My motor wo'nt turn over...
Need more info--lights work?-does it click?-clean battery cables?-will motor turn over by hand?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-07-2007, 03:16 PM   #3
corkscrew
it does not click at all....ill check if it turns over by hand now.......if it doesnt what is the problem?
Old 04-07-2007, 03:36 PM   #4
cdowns
cdowns's Avatar
first obvious place to start is the battery disconnect tboth wires and clean them then reinstall them/ after that check to see that the truck is in park or neutral then theres the neutral safety switch thats on the steering column near the floor
Old 04-07-2007, 03:32 PM   #5
watahyahknow
watahyahknow's Avatar
check if the lights work it sounds like the battery has gone to batteryheaven.
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 04-07-2007, 03:38 PM   #6
corkscrew
BTW the motor does turn over by hand
Old 04-07-2007, 04:11 PM   #7
corkscrew
all of the lights work.......how is the neutral safety switch hook up properly?
Old 04-07-2007, 05:58 PM   #8
Eichorst69
If the battery is good and the cables clean, have someone tap the starter with a hammer while you try to crank it. It could be the starter giving you trouble now. "Tap" it hard!
Rob
Eichorst69 is offline   Reply With Quote
Old 04-07-2007, 06:51 PM   #9
jhow66
jhow66's Avatar
Automatic or manuel?
Old 04-07-2007, 07:38 PM   #10
corkscrew
its manual whit shifting on the column......anyways i got it started but only in neutral and not park
Old 04-07-2007, 09:36 PM   #11
jhow66
jhow66's Avatar
You have a automatic transmisson- not straight shift. (no clutch-right?). Your problem is the netural safety switch which is mounted on the steering column under dash. Loosing the two small screws holding it. Put shifter in park. Move the switch toward the pass. side a SMALL amount and try to start-no start move a little more. When it will start, tighten screws. It now should start in park and netural.
