04-07-2007, 05:51 PM | #1 |
Excessive vibrations?
My 72 C-10 (350/3sp) is vibrating badly under acceleration. Before there was only a slight vibration, but now it shakes the whole truck. It is most noticeable from a stop. At cruising speed it is fine (until acceleration).
What's most likely wrong? Thanks Last edited by young grasshoppa; 04-07-2007 at 05:51 PM. |
04-07-2007, 06:43 PM | #2 |
Dave's not here, man
Re: Excessive vibrations? :confused:
Do you have a 2 piece drive shaft? I would think it's the center support bearing, but that usually causes a vibration even if you aren't accelerating (driving) You could check it if you have one just to rule it out.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 04-07-2007 at 06:44 PM. |
04-07-2007, 07:01 PM | #3 |
check for worn broken motor mounts
04-07-2007, 07:11 PM | #4 |
U-joint or center support. Better get it fixed or you are in for a surprise.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
04-07-2007, 11:42 PM | #5 | |
Ha Ha Surprise it was! I tried going for another spin, and barely made it down the road. I shattered the drive shaft off of the U Joint. There is play is the support bearing. Luckily it was just down the road from the house. So now there are two things to fix. Thanks for the help |
04-07-2007, 07:19 PM | #6 |
its all about the +6 inches
if you sit still, left foot on the brake, right one stabbin the gas... do you feel the same vibration?
If so, you need to look towards a tune up. |
04-07-2007, 07:25 PM | #7 |
04-07-2007, 07:27 PM | #8 |
