Old 04-07-2007, 07:25 PM   #1
skokie
skokie's Avatar
Heat Riser Gasket
Well I am stuck with a heat riser and the time has come to put the ram horns back on. I got the passenger side on but now I am stuck at the drivers side. The gasket has a triangle bolt pattern.The opening is almost 2 1/4 on the heat riser but all of the gaskets that I have asked about have a 2 1/2 opening. That seems to big to me. Does anyone know if this is the correct gasket size?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 04-07-2007, 08:01 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: Heat Riser Gasket
pictures we need pictures
rage'nrat638 is offline   Reply With Quote
Old 04-07-2007, 08:04 PM   #3
jerry moss
Born Psycho
jerry moss's Avatar
as long as the gasket will fit the bolt pattern you should be fine, just make sure it has the steel ring in the center and both surfaces are clean. i can get you the correct one monday when i go back to work if you don't find the right one before then. p.m. me if you need one.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is online now   Reply With Quote
Old 04-07-2007, 08:48 PM   #4
skokie
skokie's Avatar
Heres the pic..
68 build thread
Old 04-07-2007, 08:49 PM   #5
skokie
skokie's Avatar
The gasket has a 2 1/2 opening and the heat riser itself it almost 2 1/4.
68 build thread
Old 04-07-2007, 10:05 PM   #6
skokie
skokie's Avatar
Ttt
68 build thread
