04-07-2007, 09:27 PM | #1 |
electic plug on trans
Thanks in advance to great site with great contributors! What's the electical plug on the trans (TH350) driver's side?
04-07-2007, 09:31 PM | #2 |
Re: electic plug on trans
its a stupid spark control for the emissions stuff not needed in real life unless you're an al gore fan
04-07-2007, 09:31 PM | #3 |
GM Gypsy
Welcome! Try this link: http://www.novak-adapt.com/knowledge/th350.htm
Hope it helps!
1972 Custom 10 Deluxe LWB 4x4 2003 Power Wheels Barbie Jeep (2 daughters ya know) 2004 Silverado Crew Cab Z71- Sold Here's to your coffin... May it be built of 100 year old oaks which I will plant tomorrow... |
04-07-2007, 09:51 PM | #4 |
Because, I thought it had something to do with back up lights ... also have a set of wires on a plug (brn, ylw, grn, lt grn) that looks like rear lights that does not go anywhere.
04-07-2007, 09:54 PM | #5 |
I believe that one goes from the firewall plug all the way back to the tail lites...
04-07-2007, 10:57 PM | #6 |
ewwww al gore : (
04-07-2007, 11:30 PM | #7 |
I survived Dead Man's Curve.
The back up light switch is actually located on the steering column (if it is an auto trans column) right before it enters the firewall (above the pedals).
"The people should not be afraid of their government. The government should be afraid of it's people." "The Hurricane" 1967 Chevrolet C10 350 Eight Cylinder, 700R4 BowtieOverdrive Cherry Bomb... Disturbing the Peace Since 1968. |
04-07-2007, 11:34 PM | #8 |
That's the wire for the TCC, torque convertor clutch.
98 Neon 97 Grand Prix GT 02 Grand Prix 40th Anniv. 86 GMC 5.0 77 Olds 98 6.6 REAL AMERICANS, DRIVE AMERICAN |
04-08-2007, 07:18 AM | #9 |
That switch indicates that the tranny is in high gear, and it was used by the TCS (Transmission Controlled Spark) system.
Tim |
04-08-2007, 07:37 PM | #10 |
I'm not sure what year you have, but mines a 1971 Cheyenne w/TH350 and the TCS switch is on the passenger side. To my knowledge they were always on the passenger side. I haven't seen any of the repair or reference books indicate a TCS switch on the Drivers side, but I'm only referencing my production year also.
04-08-2007, 08:02 PM | #11 |
Watch out for your cornhole !
If it's a squarish plastic plug pointing straight up on the driver's side, it's for a lockup converter, meaning you have a TH350C trans.
04-08-2007, 08:15 PM | #12 |
Active Member
Mine has a round plug on drives side that hooks up the the kickdown switch on the carb. I'm a 68, with a 2bbl 307.
04-08-2007, 08:34 PM | #13 |
Tx Firefighter has it described to a T. Just don't know what should plug into it. Thanks guys.
04-08-2007, 08:39 PM | #14 |
The trans is actually later model than your truck. A lockup TH350 can actually be run disconnected, unlike some other lockup trans. I've run them unplugged for years. Don't worry about it.
