Old 04-11-2007, 02:39 PM   #1
tranz am
tranz am's Avatar
help with front coil spring compatibility
Ok Im on the last stretch of my hunt and need to know if the coil springs for 67-72 are the same as those in 73-87. I cant seam to find a 3 inch drop spring for 73-87.
What am I doing?
Im working on a 69 gmc c15. My objective is to drop the truck 5-6 inches, convert over to power front disk and retaining the stock 6 lugs appearance for the lowest price.
I have converted the 69 front end to a 78. This utilizes the better bushings offered on the later pickups and gives me the all I need to convert to disk 5 lug. This is all great if I wasn't in love with the centerline 6 lug rims I already have.
So I did some searching and I have found a 6 lug rotor that will bolt to a 2 inch drop spindle that will accommodate my stock 78 backing plate and calipers.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 04-12-2007, 04:03 AM   #2
TN70C10
Re: help with front coil spring compatibility
where did you find the 6 lug rotors? details!
TN70C10 is offline   Reply With Quote
Old 04-12-2007, 06:10 AM   #3
70GMCer
70GMCer's Avatar
I would also like to know about those rotors you found. I've been told that the 67/72 front coils do fit in the later 73/87. I am planning on doing the same thing as you are, except that I am staying with stock height.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-12-2007, 06:42 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes fellows, the 73-87 front spring is the same as 67-72. For a 3 inch drop front spring, I always use Summit brand springs. I believe the part number is Sum-G727 if I remember correctly. When you get the springs and open the box, you'll find that they are very nice "Ground Force" brand springs for an unbeatable price.
Second, the 6 lug rotors are available from any 67-72 vendor. The 6 lug conversion rotor that they sell fits any 1 1/4 inch truck spindle, whether stock or dropped.
Third, if you're looking for a 3 inch drop spindle, I believe the part number is BellTech BEL-3100. That's a 73-87 drop spindle set, 3 inch drop for 1 1/4 inch thick rotors. Summit has free shipping and they are heavy as hell, so that's where I always buy them. Beware though, the 3 inch drop spindle can cause backspacing issues, particularly with an 8 inch rally wheel. I always run a 7 inch rally wheel in the front if I run a 3 inch drop spindle. The 2 1/2 inch drop spindle is more common because they don't cause the backspacing concerns that a 3 incher does.
A 3 inch drop spindle combined with a 3 inch drop spring is not for the faint of heart. The control arm will set damn close to the ground and you will bend them if you drive without due regard. My daily driver is 5.5 inches in front and I've got to pay attention to entering and leaving parking lots.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-14-2007, 12:40 AM   #5
tranz am
tranz am's Avatar
Very nice. Glad that it will work out for the three inch drop springs.
My build thread
1969 GMC SWB
Old 04-14-2007, 03:06 AM   #6
mexgrhd68
mexgrhd68's Avatar
I've seen pictures and articles where they trim the bottom portion of the a-arm, I would say about an inch, then they go back and box in the arm for strength. helps with the spindle problem of rubbing on your tire when turning. might be something to look at.
mexgrhd68 is offline   Reply With Quote
Old 04-16-2007, 03:21 AM   #7
tranz am
tranz am's Avatar
Hmm Id like to see that got any pics.
My build thread
1969 GMC SWB
Old 04-16-2007, 03:30 AM   #8
mexgrhd68
mexgrhd68's Avatar
Tranz am, sorry I don't, seen this back in the day in some old issues of sport truck, just threw a whole bunch of those mags about 9 months ago, I had to move and didn't want to haul mags with me. sorry.
