![]() Join Date: Mar 2003
side panels and speakers in.
Just finished the side panels and speaker install. Movin on up....τΏτ
The LuvShack Garage
Re: side panels and speakers in.
bump diddy bump diddy bump
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
You made those panels?
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
Yes I did. A board member gave me a template on the sides and I traced it on to some 1/4 moisture board and cut it out. Then had it covered with the same pattern as the seats. I also have speakers in the front section on the panel.
Can't wait to retire!!
Nice job. Looks good.
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
![]() Join Date: May 2006
Bet it sounds nice with the top on and no wind blowin in your ears, looks good.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! |
Active Member
did you do any brown bread or dynamat behind them on the sheet metal? How do they sound overall? I am thinking of fabbing in a particle board sub enclosure on either side where you are showing your rear 6x9's and putting in a pair of 6x9's in the front of the side panels and dial them in as fill sound. Up front I plan on making a custom fiberglass set of kicks with separates for front imaging. I will be making my own side panels as well (I had one complete stock panel when I got the Blazer). The side panel will cover the sub enclosure except the grill on the subs. Amps will be camoflauged under the rear seat. However I'm a long way from worrying about that! I am the done frame, shell of a body stage right now. Good job!!
I had some extra dynamat and put it in there. Otherwise just those 4 cheap speakers. I did run the wireing for a sub but that will be for the next owner to install. I am building this one to sell.
Oh..never mind....
Blue, did you put the carpet kit in there, or was it already installed. The reason I ask is that I like the fact that the wheel wells are covered and I would like to find out who makes the carpet kit that has them.
1972 Blazer -6 inch lift -35 inch BFG A/T's Turbo 350 NP-205 454 BB (for now) MORE TO COME !!!!!! Now going to 2WD!!!!! Sold. ![]() ![]() ![]() I got it back after 22 years and did not even know it !!! THE STORY HERE Project Low Down Dirty Rat |
ABLZN - I am currently working on my interior and I bought a carpet kit from Tim Christian and the wheel well carpet was included.
Jeremy (NUBOMB) 72K5 CST 350/350/205 1951 Chevy 1/2 ton North Georgia Group "... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman. |
The carpet was purchaced from summit racing. And the wheel well carpet from LMC. I used 3m spray glue to hold it in as it wasn't a perfit fit. Also wouldn't recomend the summit carpet either, It doesn't cover all the way to the sides. But after install the side panels, you can't tell.
River life......
Looks sweet.
