Old 04-12-2007, 10:03 PM   #1
jorgensensc
jorgensensc's Avatar
Need help ASAP!! Tonight! Must get truck running!
Please help me! I have to have the truck running by 6:30 A.M., But I have to stop working on it within 1 hour (I have neighbors)
Bought a crappy j-yard dizzy that makes noise, but runs. Bought a new Procomp from ebay (at board suggestion) to remedy noise. Got the truck and dizzy dialed in, but the truck won't stay running!! I can get it to start and keep my foot on the gas and it will run, but the minute I let off it dies. If I turn the dizzy counterclockwise it won't start(sounds choppy and won't kick over) if I turn it clockwise it won't kick over (sounds like it wants to but won't. Right in between those two spots it will run as long as I have my foot on the gas and don't let off. Please help! Any suggestions would be appreciated!
SHawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 04-12-2007, 10:05 PM   #2
brak
brak's Avatar
Re: Need help ASAP!! Tonight! Must get truck running!
First thing i would check, is to make sure it isn't 180 out.
it seems, no matter how careful i am i always end up backwards...
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 04-12-2007, 10:06 PM   #3
panhandler62
Java Mechanic
panhandler62's Avatar
Make sure all of your connections are clean and tight and the vacuum signal is correct.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 04-12-2007, 10:08 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
double check the firing order... #7 and #5 are real easy to cross, and it'll still run wired as so.
Old 04-12-2007, 10:09 PM   #5
msgross
msgross's Avatar
did you run a "new" 12 volt switched wire to the HEI dizzy? i assume that you put HEI in if it's a new procomp? If you used the original points dizzy hot wire then it's a wire that only puts out 6 volts. Bypass it all together (cap it off) and run a new ignition hot 12 volt wire.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-12-2007, 10:40 PM   #6
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
All real good sugestions 18436572 and if it sounds good just not staying running just try and bump the idel up alittle till you can put a timing light on it. VERY small movements can change alot on timing so just a small amount will sometimes get ya there with out a timing light. OLD SCHOOL tighten down the dizzy so you can move it real hard by hand but not move when running and take a ride. Adjust every so often so it runs good on the road test.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 04-12-2007, 11:08 PM   #7
jorgensensc
Found It!!! It was a vacuum leak. The vacuum port on the back of the carb was leaking. The plug cracked and fell off and I didn't see it. I don't have a brake booster so It was plugged. Thanks for the help! Especially thanks to 67rs/ss for the phone support! You nailed it! Thanks for being persistent in making me look for the vacuum leak! Thanks for everything everyone!
Shawn
Old 04-13-2007, 12:04 AM   #8
GREASEMONKEY72
GREASEMONKEY72's Avatar
nice to hear you found it, i hate when its those little things that you forget about or overlook
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 04-13-2007, 09:39 AM   #9
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
But it really bites when it's something major
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 04-13-2007, 03:58 PM   #10
Longhorn Man
Over looking the obviouse can bite you in the rear pretty majorly, and it's happened to me more than once... that's why i normally look to what was worked on last, along with a general looking over before jumping into something big.
