Old 09-07-2002, 07:43 AM   #1
KD
Truck Nut
Unhappy Is the year of the axle stamped on the ring or pinion?
its hard to order parts when you don't know the year.
'70 3/4 manual w/350 4.56's .Doing a ground up on a '67 4x4 4"lift.
KD is offline   Reply With Quote
Old 09-08-2002, 09:06 PM   #2
Mike C
Mike C's Avatar
Some gear sets have a date code on them, and the ID code stamped on the pass side axle tube, on the top, between 4 an 8 inches from the cast section, should identify what year it is.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-08-2002, 09:23 PM   #3
Low69CST
Most rings have a machining date on them. Pinions probably do too, but never had one out. The date on the ring is an approxomite date of axle assembly.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
