New Project... Low 50
Hey all, I have been more of a reader than poster on this site for quite some time. Spend most of my time on the 67-72 side. Well here I am, forum jumper with a new project. Figured I might start my own build thread.
Here are the details: 1950 Chev 3600... soon to be lower and shorter! whats done so far: No Limit air ride IFS Suicide Doors tri-4 link with notch and bags Plan to lay running boards on 18/20 combo. Should be a nice cruiser for the wife! Some pics:
Jason 1971 SWB currently reconstructing... Dropmembers, 20/22 rushforths... Build: http://67-72chevytrucks.com/vboard/s...d.php?t=467329 |
Re: New Project... Low 50
some of the 71 SWB and the daily driver, just cause!
![]() Join Date: Mar 2007
#5 | |
Jason
nice!! love the d-max
but please tell me your gonna change that bridge.
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com Last edited by 1lowdiesel; 04-13-2007 at 04:53 PM. |
Looks like a good start. Keep us posted. My mom's sb grew to a lb
, but that's what she wanted. Good work on the '71 BTW!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe
Nice stuff! Keep us posted and take lots of pics!!!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland www.YouTube.com/user/593Films - Watch My Videos! ![]() 1977 Silverado K10 2014 Dodge Durango (Wife-mobile) 2008 Dodge Ram Lone Star Edition (Daily driver) |
very nice...you need to add a 55-59 to the fleet!
That's my plan. 1 from each series.
I have a '56, '91, '04 and now I need a 67-72!
Cool project. I like the '71 also, great color!
![]() Join Date: Jun 2002
"Hey all, I have been more of a reader than poster on this site for quite some time. Spend most of my time on the 67-72 side. Well here I am, forum jumper with a new project. Figured I might start my own build thread."
welcome to the dark side gray, I'm a forum jumper also, this forum is alot less active, so its nice to see another. you got a cool project going there. Trying to finish mine up this spring, but the little things are killing me. Kid
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 Last edited by Kid; 04-14-2007 at 08:58 AM. |
Kid,
Been watchin your thread...looking good. I am looking for a genIII motor and trans currently so that I can put in motor and trans mounts and finish up the frame. Havent been doing much last few days... went to the portland swap meet. got a hood for 60 bucks though:
#15 |
I also need some measurements if anyone can help. Getting ready to shorten my frame. I know I need to shorten 9.25", however I need thhe measurements from the each of the runningboard braces/supports for a shortbed. How far apart are each one. I dont have any runningboards yet.
Thanks Jason
#16 |
Sweet Fleet! Welcome to the 50's Club!
1959 GMC project |
#17 | |
I like the rear end set up, is the point of the square tube for the trangulated four line supported at or near the pinion flange???????
Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed 1948 F3 ford pu 1949 F1 stock V8 flathead 3 on floor 1950 F1 pu street rod 1948 F6 Ford Dually/350sbc no bed stock trans&rear 1972 El Camino 4" chop 1953 Chevy 3100 2b daily driver 1970 SB 4X4 400ci 6in lift |
#18 | |
Jason
#19 |
getting shorter... will finish up supporting supporting the frame and start boxing it tonight.
#20 | |
Curious what is involved with shortening a frame. I have a few questions. Did you support the truck on jack stands when you performed the surgery? From the photos it was hard to tell. What did you use to make your cuts in the frame. Cut off wheel or sawsall by chance. You are making nice progress. Thanks Marc |
#21 |
Marc,
It is really not that difficult, this is my 3rd shorten job. The entire frame is leveled on a combination of jacks and blocks. Just make sure it cant move. Then everything else is simple... just measure 4000 times and cut once. measure 4000 times again and weld once. measure another 4000 times just to make sure it is exactly where it needs to be. Reinforce the hell out of it, boxed it etc. Simple huh Jason
#22 |
Certified Car Nut
Nice work man and all I can say is damn I wish I had your work space.
#23 |
some more progress...
#24 |
Rear Disc Brakes...
Brackets: $70 Loaded Calipers: $66 (local Auto Parts) Rotors: $56 (Local Auto Parts) Total: $189 Rear Disc for under 200 bones...
#25 |
![]() Join Date: Jan 2004
How about some more info on the rear discs. Where to buy brackets, which calipers, and which rotors? Thanks for the help, seems really cheap for a rear disc setup. Thanks in advance!
My Suburban Project 72 Suburban 68 SWB 57 Belair 55 Cameo 06 Chevy 1/2 ton crew 09 Suburban |
| Bookmarks |
