09-07-2002, 03:08 PM | #1 |
Timing mark inch away from tab
I have a 77 truck that is basicly stock and i had a leak behind the intake maifold so i had to take everything off the manifold. When I went to set the timing I started at 8 btc then when more, but now i am about and inch from the timing tab and it is not pinging i want to go more but im hitting the manifold. Which way would I reseat the rotor to get more advance counter clockwise or clockwise.
This is a HEI dist. Thanks Eagle
77 C10 truck 355/TH350, 10:1 KB's, COMP XE256H, EDELBROCK PERFORMER, CARTER 600 CARB. |
09-07-2002, 03:44 PM | #2 |
If you cant rotate the distributor (counterclockwise) anymore, then you will need to lift the distributor 1 inch then rotate the rotor clockwise one tooth then recheck. Depending on how far you have it out, your might need 2 teeth.
As I general rule I prefer to bump the engine over until the rotor is pointing directly to the front (right at me), This is your baseline incase you over rotate the rotor or forget where you where. Make sure your mechanical (centrifigal advance) is working and the vacuum advance is ok. |
