Old 04-14-2007, 05:08 PM   #1
squeaky69
Question no gas
i need help , im just getting a little bit of gas to carb is it the fuel pump not doin right or is my tank stopped up. i took the gas line off just under cab and had nothing, could my fuel pump be weak enough to where its not really got a good gas flow going yet , and i have two lines going from tank all the way up to fuel pump ,what is the other one for, its not hooked up to anything, somebody please help
squeaky69 is offline   Reply With Quote
Old 04-14-2007, 05:12 PM   #2
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: no gas
Sounds to me like the pick-up filter screen may be cloged in tank. The other line is a return line. I would recommend if they are the stock lines replace em' gas line usually go bad from the inside out causeing problems also as you mentioned resticting flow. Hope it helps RJ22
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 04-14-2007, 06:40 PM   #3
centsless
sufficiently talented fool
centsless's Avatar
Re: no gas
Also check for an air leak between the pump and the tank. If there is a leak, it will not pick up the fuel. Use shop air to pressurize the tank some, and then look for a damp area on the lines. The leak will not show up without doing that, because there is not enough fuel in the line to leak.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 04-14-2007, 09:21 PM   #4
WorkinLonghorn
WorkinLonghorn's Avatar
Re: no gas
If it was me,and it was an old pump or I didn't know it's age,then at this point I would replace any and all rubber fuel sections,and get a new (non-auto-zone) pump. You don't need problems down the road and the entire bill will be quite low. Very inexpensive peace of mind IMO.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 04-15-2007, 01:10 AM   #5
sodak69c10
sodak69c10's Avatar
Re: no gas
sounds like everyone is giving you good advice i figured i'd share a funny story about the same problem accept i had a dead mouse floating in the tank and it would get next to the pick-up line and stop flow and i'd have to sit there for a while then start for home , i had my tank boiled out at a radiator shop and it all good now,
p.s. your second fuel line is a return by the sounds of it if you get a new pump and it has a small and a large nipple for rubber hose the smaller is used as return to divert fuel back to tank and help with vapor locking regulate fuel pressure , i'm assuming that the second hose is plugged off right now any how cause there are several pump styles and some don't have returns, like my carter high flow
sodak69c10 is offline   Reply With Quote
Old 04-15-2007, 01:30 AM   #6
cstm68
cstm68's Avatar
Re: no gas
hahahahahahah did you know you had a dead mouse in the tank ???
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 04-15-2007, 01:33 AM   #7
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
Re: no gas
Is there any gas in the tank? Had to do that. You didnīt say that you have a full tank or something like that.
When you take the line off under the cab try opening the gas cap, maybe there is a vacuum and the gas canīt flow. Just like centsless said, you can put a little pressure on it to see if the fuel even flows out of the tank.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 04-15-2007, 01:38 AM   #8
sodak69c10
sodak69c10's Avatar
Re: no gas
actually, the tank came froma a doner truck cause it was a new tank so i figure it was good , i reomoved the tank after it kept dieng and i drained in and heard somthing rattling around in it so i shuck it upside down and "several" mice fell out they even got more out wen they boiled it, goes to show even if it new never hurts to clean it
Old 04-15-2007, 10:24 AM   #9
squeaky69
Re: no gas
thank you all,the truck sat for a few years before i got it, ill have pics soon. im gratefull for all the help
Old 04-15-2007, 11:21 AM   #10
blukangoo
blukangoo's Avatar
Re: no gas
Try some fresh gas, old gas doesnīt burn right.
Thatīs not a joke either.
My C10 Diary
Our cars:
Old 04-15-2007, 06:42 PM   #11
chops333
Re: no gas
try pulling the sending unit a push a coat hanger thru the the metal tubes mine was clogged up restricting fuel flow i tried 2 new pumps before i figured it out good luck
chops333 is offline   Reply With Quote
