04-15-2007, 08:50 AM | #1 |
plz guys! whats up with this!
I know this is a likely a dumb question but it doesnt look right to me. Im putting a new gasket on my oil pan and the larger of the rubber end seals doesnt seem to fit. here are some pics does this look right to you?
Notice the huge gap on both ends A close up one of the gap Thanks for any comments!
69 C10 a long way from done |
04-15-2007, 08:54 AM | #2 |
CAN'T FIX NOTHIN
Re: plz guys! whats up with this!
nothing wrong there , just put some silicone glue on the pan and the gasket and let it dry overnight then install it , it will stay leak free for years , if you put it on before the glue dries it just sqeezes out the sides and will leak as soon as you put oil in it ,,,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
04-15-2007, 08:59 AM | #3 |
will those gaps compress out without tearing the gasket away from the silicone? that second pic is decieving the gap is much larger when I equal them out. Thanks Im gooping it up right now!
69 C10 a long way from done Last edited by dogfishguzzler; 04-15-2007 at 09:00 AM. Reason: du |
04-15-2007, 09:10 AM | #4 | |
CAN'T FIX NOTHIN
I have built 250's 283's 327's 350's 400's this way and it won't leak , you can do the intake manifold the same way , the key is to let the glue dry , another way is to attach the oilpan without those rubber insert's and just finger start the bolt's then squirt the opening's full of glue let it dry overnight then tighten it up , this way to will be leak proof
04-15-2007, 10:35 AM | #5 |
Should I let the glue on the block dry overnight too before I put the pan back on?
04-15-2007, 09:05 AM | #6 |
I dont like the 4 pc gaskets, leak prone. i use the 1piece gasket.What you have is normal it will compress when installed.
04-15-2007, 10:37 AM | #7 |
gearheads been using the 4 pc pan gaskets for years and they do take a little trial and error to get leak free. The 1pc is more forgiving but for double the price.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
04-15-2007, 06:03 PM | #8 | |
I used the 4 piece Felpro gaskets plus silly cone on my recent 454 build. Spent hours trying to stop the leaks once the engine cranked up. Do yourself a favor. Use a 1-piece gasket. I will be from now on.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe Last edited by mnunn454; 04-15-2007 at 06:04 PM. |
04-15-2007, 09:13 AM | #9 |
you guys are awsome thanks alot!
04-15-2007, 10:39 AM | #10 |
1 pc all the way.......
1997 GMC Sierra Ext 1965 Mustang |
04-15-2007, 12:55 PM | #11 |
Sleep-Deprived
Good tip 19673ontree, since you can't get a 1 piece for a 292.
1971 K/10 Long Fleetside 350/350 - 6" Lift 1969 C/10 SWB 292 - Sold It |
