View Poll Results: 70 step side 31inch tires | |||
Stay with stock suspension hight | 13 | 81.25% | |
Add 4 inch lift with 31 inch tires | 3 | 18.75% | |
Voters: 16. You may not vote on this poll |
04-15-2007, 09:07 AM | #1 |
4" lift with 31"tires?
I own a 70 stepside with 31s on it. do you guys think a 4 inch lift is to much? Or iam ? wpvtx |
04-15-2007, 09:22 AM | #2 |
Re: 4" lift with 31"tires?
Add the lift, but start saving for some larger tires, 33's or maybe 35". Your 31's will look small with the lift.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
04-15-2007, 10:31 AM | #3 |
Few things look more retarded than a lift with tiny tires. If you are going to get more body clearance, get more axle clearance with larger tires.
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift. '77 400sbc, '82 axles, d60front, 14bolt rear. Probably some 285/75/16 Toyo m/t's on my stock rims coming up. |
04-15-2007, 11:00 AM | #4 |
River life......
I would stay stock height with 31" tires. If you go 4", then upgrade to 33" tires.
04-15-2007, 11:59 AM | #5 |
What he said.Maybe 2" w/31s.But,why bother?2" lift w/32s or 4" w/33s.
04-15-2007, 01:04 PM | #6 |
2" with 285/75/16 (33x11.5) ought to work also, or may need a TINY trim on the bottom corner of the front of the front wheel well opening.
04-17-2007, 09:04 PM | #7 |
Does anyone have a pic of a pickup with this setup?
1972 Chevy LWB K10 Custom/Deluxe Earth first! We'll log the other planet's later. |
04-17-2007, 09:15 PM | #8 |
mine are 33 x 10.5 all depends on tire brand, rim width and backspace. Worn springs will alter things too so it's hard to pick a "perfect" combo unless you try it. Of course you could do Dustin's 6" lift and not worry about anything less than 3 foot tires!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
04-17-2007, 09:42 PM | #9 |
Currenly installing the 4" lift. My question is that my front drive shaft at the front u-joint there is only 1 not the normal 2. Is this normal? the LMC catalog shows a shaft with a total of 3 universals in it - also seems to be to short to reach the yoke when fully extended. Mine only has 2 front and back. Is the 73 and up driveshaft interchangable?
Thanks. wpvtx |
04-27-2007, 11:46 AM | #10 |
Not yet. BUT looking at my rearch/add a leaf lift from the spring shop on Mossy Cup in Boise, the 285/75/16's would look most proportional. I still may try to shove 35's in there, but trimming will be required, and I will almost certainly need to put a sway bar on to limit wheel travel. The nice thing is, the stock rims on my rig are 7.5" wide, and they will work fine for the 285/75's, saving me the cost of wider rims at a time when I plan on spending a lot on the truck.
04-15-2007, 06:37 PM | #11 |
Yeah,that`s a nice beefy/stockish look.
04-15-2007, 07:17 PM | #12 |
I've got 35" BFG on both my K20s with the 4" lift.
04-15-2007, 07:23 PM | #13 |
that's neat paint, green outside and blue inside! just kidding,,,, nice set of trucks...
Here's my stock K-10 w/ 33's x 10.5's I'm adding a "add-a-leaf" to the rear to take out any sag and maybe add an inch or so. If you lift then you have to make it look like one of the above trucks, 33" min or 35"....
04-16-2007, 01:11 AM | #14 |
Chevys Kick A$$
I agree if you get the 4" lift get some 33''s atleast. Big lift and small tires = major dorky look.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
04-16-2007, 03:43 AM | #15 |
Born To Lose Club
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Brian Smith - "Born To Lose" 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
04-16-2007, 03:04 PM | #16 |
I'd say stay like you are, but if you're going to lift it, you'll need bigger than 31's...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
04-16-2007, 05:09 PM | #17 |
K5Camper
Like it was said before, if you are only going to have 31's you don't need to lift it. If you want to put a 4" kit under it, then plan on getting larger tires (33 or 35's) down the road. I thought mine looked a little goofy with 33's and the 4" lift But i couldn't afford to do the lift and tires at the same time. So I bought the 35's later. The look is a ton better as the 35's fill the space better and make it look less top heavy. In other words the 35's made it look more proportional.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper Last edited by Zoomad75; 04-16-2007 at 05:11 PM. |
04-16-2007, 05:15 PM | #18 |
Tool Addiction=Money Shortage
Every one here has said it perfectly.
4" and 35s here
1967 K20 400TBI SM465/NP205 posi front, Detroit locker 4.56 rear |
04-17-2007, 10:27 AM | #19 |
Thanks for time to give feedback everybody. Ive since started to do the lift and Ill get the tires later. Ill send some silly picks of my truck with the little boy tires on it soon.
wpvtx |
04-17-2007, 06:01 PM | #20 |
It will look like a monster truck travelling between truck shows...lol
04-17-2007, 10:11 PM | #21 |
04-17-2007, 11:10 PM | #22 |
Heres some picks of the truck. Not much to look at right now but she will get there. As for the front driveshaft this is fully extended and binds when rotated at this angle. So thats why im trying to look into a 73 and up shaft. All the junk yards around here are more of scrap yards - they dont hang onto anything older than 7 to 10 years old.
1970 Chevy K10 350 CID with 4 speed 4" lift with 86 Dana 44 Front disk brakes Electric fan/Internal regulated Alt. |
04-17-2007, 11:17 PM | #23 |
The wifes reaction is not going to be nice when I tell her I need to replace the brand new 31" tires with 33 or 35's lol.
04-27-2007, 12:04 PM | #24 |
If you need to go cheap, you can go the way I did on lift, with the tires that I outlined. Trade in your 31's at les schwab if you have them in your part of the o****ry, shouldn't cost too much to upgrade.
04-27-2007, 12:51 PM | #25 |
One of the funniest things I have seen was when i was in Guam. You would see all these wicked trucks with huge lifts and a ton of suspension work running around town on 4 spares. Little 15" steels with car tires and it made me laugh every time.
I asked a guy at a local shop why they were all like that and he said it was for work. These guys put all this money into the truck, but still use them as daily drivers. So rather than wear out the tires they use on the weekend for wheeling, they run street tires (like the monster truck loading picture). Then as soon as work is done on Friday, out come the boggers for play time. Still made me laugh every time I saw it.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
