Junior Member
new gauges...pics please
I am thinking of taking the factory gauges out of the 72 and replacing with updated newer gauges. Have any of you done this...if so do you have any pics I can see before I make my mind up? Thanks Don
------------------------------------------------- 1972 Chevy C-10 Short Bed (Ol'Blue) 350/350TH 2003 Chevy Silverado Z71 2007 Honda MiniVan...yup we should all be so lucky |
Re: new gauges...pics please
I'm getting ready to go Fuel Injected and these are what I will be going with.
R.I.P. Killer 71 10/26/07 |
Junior Member
I like that, as far as installation was it hard? The middle gauge what all is on that??
#4 | |
Active Member
I'm curious where you found these? I am only seeing them sold as a kit, tach with quad or MPH with quad were you able to buy them as seperate gauges? Also are the sizes you used 5" for the tach and MPH and 3 3/8 for the quad? Thanks, -Fred
"The Great State of Florida" |
![]() Join Date: Feb 2000
Here are the AutoMeter Phantom guages I am using (I later swapped the tack and speedo to the opposite positions).
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
They will be all electric haven't got em in yet;
There is quite a few folks doing these. Depends on your taste in gauges. Good luck with the project.
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e) 1990 K1500 Daily ![]() Last edited by jackyl9999; 04-16-2007 at 12:14 AM. |
That is the same setup I am going with in the Cheyenne Killer. For some odd reason my truck was only optioned with the idiot lights.
jackyl9999 - is that a dimmer switch on top of the clock? Did you get those pre- made or did you order those separately? It looks really nice.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
That is my high beam indicator above the clock. I bought the gauges, a new new bezel, got 1 piece of lexan, and a aluminum plate to mount the clock in. It was quite a project. btw the turn signal and high beam ind. are painless lights. Thanks !
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e) 1990 K1500 Daily ![]() |
Active Member
Killer71,
Did you have to mix and match those autometer gauges? I was under the impression that the quad gauge only came in a kit of sorts. I've been wanting to do the same set up with black face gauges. Not trying to hijack anything here post wise, just curious. -Fred |
#12 | |
Questionable
3-3/8" quad guage Autometer part # 1312 (or #1612 or there are others) http://autometer.com/cat_gaugedetail...earch&gid=3483 5" Tach Autometer part # 1399 http://autometer.com/cat_gaugedetail...earch&gid=3308 5" Speedo (elec, programmable) Autometer part # 1389 He's doing a GenIII swap also, I think gringoloco is too (?), so we can get away w/electric speedos. I need to screw around some more and find something fitting for me. I'll miss the old blinkers unless I can find someway to mount them somewhere. If you want to buy these parts separately, go to jegs.com or summitracing.com and type in the four-digit number of the Autometer part, and you'll find it there.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 04-19-2007 at 02:34 PM. |
![]() Join Date: Feb 2001
There are 2 or 3 3 3/8 Phantom oil pressure guages on evil bay was I type.
Here's my set up Covan's panel with Autometer Ultralites. A bit $$$ but I like them, way more accurate than the factory gages !!
