04-16-2007, 08:42 PM | #1 |
PROJECT 7DEUCE
bump stop on the new strong arms..
The new strong arms I got have a bump stop in the kit where have you guys mounted yours as there does not seem to be any pre drillerd holes?? Btw nate I got the new shocks and mounts just have to re drill the holes in the frame to mount em since I filled in the holes.... thanks for the great service nate and tony from air ride... both are great people thank you..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 04-16-2007 at 08:43 PM. |
04-17-2007, 12:48 AM | #2 |
A guy with a truck
Re: bump stop on the new strong arms..
I've seen most guys put it on the corner of the upper plate. Just replace one of the nuts/bolts with the bumpstop. The arm should contact it when aired out.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-17-2007, 07:51 PM | #3 |
PROJECT 7DEUCE
Thanks Il put that on the list of things to do..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
