04-17-2007, 06:48 PM | #1 |
Hellasick
changing steering stop
How much should I cut off?
Got my '85 spindles on the 70, and like I read on here, the steering stop won't let it turn all the way. I haven't attached the tie-rods yet. I plan on cutting the stops down. There is about an inch difference from the tie-rod and its location on the spindle. I would think you would want the spindle to stop before the steering box stops turning. Any suggestions before I start cutting would be helpful.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
04-18-2007, 06:58 PM | #2 |
Hellasick
Re: changing steering stop
Any help out there?????
04-19-2007, 08:40 AM | #3 |
I will try to get some numbers for you tomorrow. Can't send pics, so I will try to explain.
04-19-2007, 08:10 PM | #4 |
Hellasick
Thank you in advance.
04-20-2007, 10:47 AM | #5 |
Sorry, I didn't get into the garage last night. Will get it for you over the weekend. Lane
04-20-2007, 10:53 PM | #6 |
Hellasick
Not a problem...at your leasure. Would rather do it right than again.
04-21-2007, 02:58 AM | #7 |
aint that the truth, would you tell that to a buddy of mine? maybe he'll get it more comeing from someone else
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
04-21-2007, 03:47 PM | #8 |
Hellasick
I'll tell'im that...nobody wants to believe it the first time they hear something. They could hear it from the blithering idiot down the street and believe them, as long as it is the second person to say it.
04-25-2007, 11:18 PM | #9 |
Son of a gun
Trial and error is the method I will be using this weekend to do the same thing. I am thinking that I can get some measurments from the old spindle, at least to get in the ball park. Tell you what, you keep me posted, and I'll keep you posted
Bill BEATERS ARE NEATER |
04-25-2007, 11:27 PM | #10 |
Hellasick
Sounds like a plan
Was planning on getting mine alligned, so everything at least started in an equal position on each side. Pop the outers out again (should not change the alignment). Then just slowly start grinding until the stop hits before the box stops turning. Grind, loosely install tierod...repeat as necessary. followed by Might even go as far as making a patern of the first side to make the other side a little easier and faster. Course that is if the &^$&^#$@ing rain will stop so I can get the brakes finished in the first place.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys Last edited by 70C10Toejam; 04-25-2007 at 11:33 PM. |
05-01-2007, 11:08 PM | #11 |
Hellasick
made any progress on this B.T. Knuckle????
mine is finally driveable...to be alligned soon.
05-01-2007, 11:19 PM | #12 |
Son of a gun
I had visitors from out of state this weekend and did not get ANYTHING done! How much did you cut off? I want DETAILS!!!
05-01-2007, 11:23 PM | #13 |
Hellasick
no cutting yet...but hopefully they will go under the grinder soon.
05-02-2007, 12:03 AM | #14 |
Son of a gun
Aww man, I though you would do the hard work for me
05-02-2007, 12:10 AM | #15 |
Hellasick
I DID do all the hard work. ...just not on the stops
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys Last edited by 70C10Toejam; 05-02-2007 at 12:10 AM. |
05-02-2007, 12:15 AM | #16 |
Son of a gun
I hear ya! Did all that myself ...
