Old 04-18-2007, 12:15 AM   #1
MisterE72
Keep Your Nose Clean
Metal or Poly fuel tank?
Greetings fellow truck enthusiasts. I'm not sure if I should get a metal or poly rear conversion kit for my 72 C10. Can anyone who has made the conversion share their thoughts or recommendations? Does one require more prep work than the other? I would love to go aluminum, but hey, I'm on a teachers salary (and loving it..teaching..not the salary). Thanks.
MisterE72 is offline   Reply With Quote
Old 04-18-2007, 12:19 AM   #2
shifty
Questionable
shifty's Avatar
Re: Metal or Poly fuel tank?
Poly is easier install, the absolute cheapest solution and (this last part is just opinion) rarely looks "damn good". Admittedly, in this subforum within the past 2 weeks, I did see a damned fine looking poly tank install, and wish I'd have asked the person what their setup was.
Stock replacement steel (like the one ECE sells) is super expesnive, looks great when installed, and is solid. Looks as easy to install as the poly tank, but costs 3-4 times more.
Custom Steel or custom Aluminum (got my Aluminum tank from FuelCellGuy) is a little more complex to get mounted up, doesn't quite look as good as a steel tank, but I think overall if it is installed well, it looks good. Price is about 50% more than poly and looks better than poly.
Choosing a tank is a tough choice! I feel your pain, I finally broke down and bought mine from FuelCellGuy with the pump and sending unit already installed for a little over $600. Definitely well worth it - the same setup in poly was around $400, and in steel I would have paid over $1200.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-18-2007, 06:06 PM   #3
MisterE72
Thanks for sharing your advice Shifty. Anyone else have anything else they can add to this?
Old 04-18-2007, 06:51 PM   #4
ChevyDude
FuelCellGuy...is the ticket!!!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 04-18-2007, 07:29 PM   #5
rauto13
saving one more
rauto13's Avatar
I bought a poly tank and have now replaced it with an aluminum tank. The poly tank I bought had a small fill neck for the fuel fill and with the wall thickness necessary on the poly tank, the inside diamater of the fill on the tank was smaller than my thumb. Whenever I would fill it, I could not use the slowest automatic setting on any gas pump and had to barely let the fuel flow in or it would cut off the gas pump or backwash out the fill neck. I did have it properly vented with a 5/8 hose, so that was not the issue, it was the fill neck size.
Also after a while, the poly tank started deforming as the part of the tank that sits against the lower part of the frame rails started trying to creep up inside the frame rails (if that makes sense). The sides were bowing in and the bottom was starting to bow also.
My opinion is I will never use a poly tank again. I have one in the garage I will give you.... If ya want it.
72 Chevy longbed - now for parts
69 Chevy short fleet - needing some love
70 RS Camaro - needing more love
driver - 96 GMC X-cab
rauto13 is offline   Reply With Quote
Old 04-20-2007, 12:17 AM   #6
MisterE72
Thanks Rauto13. Sounds like those poly tanks may not be the best thing to go with. Where did you get the aluminum tank? How would you compare the install to the poly? Any pics?
Old 04-20-2007, 01:08 AM   #7
brak
brak's Avatar
you can get a OE steel blazer tank for $25 as both FrizzleFry and i have posted in the last few weeks.
requires a little modifying of the fuel neck to get it where you want it, but hell, for $50 shipped, you can't beat it.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 04-20-2007, 11:04 AM   #8
rauto13
saving one more
rauto13's Avatar
sorry, no pics at this time, tank is pulled out of truck as the truck got hit & totalled. If I remember correctly, I bought the tank from CPP. But the one I bought has the fuel fill too low on the side and requires some frame trimming. The tank comes with a piece to weld into the frame after trimming to clear the fuel fill. It was farily expensive when I bought it.
I am thinking that FCG or a steel tank is the way to go, I found out about him after buying this tank. I have seen some nice installs of FCG tanks and also the steel tanks discussed above.
Old 04-20-2007, 01:42 AM   #9
TN70C10
yeah , there is no way i would pay even 1/3 of what some of these aftermarket tanks cost (like ece). summit has fuel cells in a # of shapes and sizes. of course its going to be a little harder than a bolt in kit but if you save $500 dollars by doing an xtra 2 hours worth of work then your paying yourself $250 an hour. hell , just call me , ill be glad to work for $250 an hour.
TN70C10 is offline   Reply With Quote
Old 04-20-2007, 01:51 AM   #10
A.P.
Black 72 Chevy
A.P.'s Avatar
MisterE72
Here is a link to one member's rear tank install. Good info.
http://67-72chevytrucks.com/vboard/s...highlight=tank
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
Old 04-20-2007, 02:21 AM   #11
cstm68
cstm68's Avatar
i used an aluminum 18 gal tank
the are some instal pics in my build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223308
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 04-20-2007, 02:41 AM   #12
GREASEMONKEY72
GREASEMONKEY72's Avatar
look at racecar fuel cells, poly tank inside of a metal can, or go to your local wreckingyard and nab a tank from a burban or something
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 04-20-2007, 04:27 AM   #13
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
If your buying a stock replacement steel over poly, anything else is, well anything else
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-20-2007, 09:49 AM   #14
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
A complete new steel Blazer tank kit is about $200, that includes straps and a 90 ohm sending unit. That's what I have. It's an inexpensive conversion kit in my opinion.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-20-2007, 10:14 AM   #15
shifty
Questionable
shifty's Avatar
And if you need to install an electric pump, then ... Go to Tanks Inc.:
http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
I'm using either part #PA-2 or part #PA-4 in my setup (FuelCellGuy will send you a tank with one pre-installed for a small fee). Pretty easy to work with. Comes with the complete assembly AND the pump and any hardware and gaskets you need.
