![]() Join Date: May 2006
BIG J, Door opening Measurements.
I hope this picture is clear enough,I had to take the door off to get a good shot of the opening. The arrows are pointing to the locations I used for the measurements. Good luck.
The bottom measurement should be 35-7/8", My Bad.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! Last edited by RustyParts; 06-15-2007 at 08:56 AM. |
Re: BIG J, Door opening Measurements.
Thanks! Perfect timing.
![]() I'm starting my tube doors this weekend and taking measurements from the other blazer was on the 'to do' list but you just saved me the time. Another place to find the measurements is in the factory service manual, in case anybody was wondering. |
Future TOTM Winner
I was about to ask this question actually! I Installed new Poly Body mounts a couple of months ago and I wanted to double check my work.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
![]() Join Date: Apr 2000
this would be good in the faq board!!!
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Its lookin' like a Blazer!
Thanks Rusty.... That is some awesome stuff right there. Helps a whole bunch.... This gets my vote to go in the faq section...
Hey Rusty, any chance the bottom measurement of 33-7/8" should be 35-7/8"?
Just checking... |
USMC
right?? maybe his aren't perfectly straight I have a factory assembly manual and they draw a straight line down for the measurement, not showing a difference in length Ill have to check it out again
Semper Fi |
#9 | |
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
Yor right, I must have thinking one thing and typing something else, my bad.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! |
The LuvShack Garage
Good pic to have, right click and save
USMC
OK here are a couple scans from the book. if you can make more sense out of them than I let me know LOLOL I have not read the thing cover to cover I just got it and have not spent allot of time with it. If i find more on the doors Ill post it up.
Semper Fi |
