04-19-2007, 10:56 PM | #1 |
Weldin' it up
How to mount power steering with headers?....pics please
I am gettin a set of headers for my truck, and on exhaust manifolds there is a mounting spot for the power steering pump and reservoir. Where would I mount the pump and reservoir with headers?
Paul
-Paul- RIP El Jay Dirt is for Racing, Asphalt is for Getting There If need be, send me an e-mail at cbm_racing_90@hotmail.com 1970 Custom/10 LWB 4X4 350/TH350 2003 Silverado 1500 Ext. cab 1974 Kawasaki 175 F7 Enduro 2002 Polaris Edge X 700 |
04-19-2007, 11:21 PM | #2 |
Re: How to mount power steering with headers?....pics please
If someone doesn't beat me to it...I'll take pics for you tomorrow.
Alex 1971 Lil' Red 350 SBC 700R4 |
04-19-2007, 11:25 PM | #3 |
which one is the type pump and brackets you have?
heres three different types Last edited by rage'nrat638; 07-12-2007 at 06:54 AM. |
04-19-2007, 11:33 PM | #4 | |
Weldin' it up
Thanxs, Paul
04-20-2007, 06:23 AM | #5 |
blood type; Retumbo
I have the one in the second pic. I cut off the upper part where it used to mount to the manifold. it's been that way for 4 years now and the belt is tight. the pump stays straight also. I think it's due to the lower part being cast iron. mine came from a 79 van. I also used the van hose. I just starightened out the bend in the metal tube since none of the parts stores had the application correct hose in stock.
04-20-2007, 06:24 AM | #6 |
Watch out for your cornhole !
You have long water pump on your truck then. You'll need to install your headers and then fabricate a spacer to go between the pump bracket and the header flange. I always use a small piece of tubing about an inch long. It just has to make up the difference between the original thick exhaust manifold and the newer thin header flange.
