04-21-2007, 09:18 AM | #1 |
Ground straps
I have 1 ground strap that goes from the batt to the engine and that's it. I've read that you should have 3, so where do the original ground straps connect to or where is th best place for them?
72 C10 lwb fleetside -stock 350/350 combo |
04-21-2007, 09:34 AM | #2 |
Re: Ground straps
On mine there are two straps mounted between the firewall and the rear bolt on each valve cover and I'm not sure but I think the other is mounted under the cab from the front cab support to the frame.
Doesn't really matter as long as they're between the frame and bodymetal, the cab and bed cushions kinda act like insulators so you need the straps to provide a good ground from the frame to body.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! Last edited by RustyParts; 04-21-2007 at 09:34 AM. |
04-21-2007, 10:10 AM | #3 |
Re: Ground straps
What RR said. This is where I usually start:
Body (Cab and Bed) to Frame Frame to Motor Motor to body Scrape paint to bare metal to get as good of contact as you can.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-21-2007, 11:59 AM | #4 |
F.A.S.T. president
Re: Ground straps
Batt to motor (4 gauge min.)
Frame to cab (strap or 10 gauge min) Motor to frame (strap or 10 gauge min) I like this better then motor to cab, cab gets its ground from the frame to cab Optional Batt to rad support ( 10 gauge, I like to run this to help with grounding of lights, horns, electric fans, etc) The bed does not have any rubber isolators just make sure you have clean metal between frame and bed or add a strap if you have ground issues with tail lights. Clean paint from surface for ground terminals, use a star washer between terminal and surface (frame and body) then brush over with some liquid electrical tape to keep from corroding.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" Last edited by jamis; 04-21-2007 at 12:09 PM. |
04-21-2007, 05:13 PM | #5 |
its all about the +6 inches
Re: Ground straps
there's supposed to be straps to the bed from the frame too... and if you have a wooden floor, they are pretty important.
