Old 04-22-2007, 05:13 PM   #1
Jtrux
I'm a poor spectator
Jtrux's Avatar
Big ass clutch pedal spring
I took off that big ole giant clutch pedal spring under the dash to see if it would make for a more comfortable clutch pedal (it does) but got thinking, does this cause anything to mess up. I don't notice anything weird about it but I also got to thinking that there has to be a reason GM put it thataway and i'm sure I would of heard something about it if it was such a great thing to do. Am I wrong, should I put it back?
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 04-22-2007, 05:15 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Big ass clutch pedal spring
well, the weight of the pedal could cause a light 'riding the clutch' condition.
I would hook it back up, and see if you could locate a lighter spring maybe.
Old 04-23-2007, 12:08 PM   #3
DUD2STUD
DUD2STUD's Avatar
Longhorns right I took the spring out of my 61 years ago and it slowly whore the clutch out. Just find a lighter spring any spring that will hold the pedal up
DUD2STUD is offline   Reply With Quote
Old 04-23-2007, 06:27 PM   #4
Big Block
Big Block
Big Block's Avatar
Find a lighter spring. The two spring work together to keep the throwout bearing from riding on the pressure plate and causing wear on the clutch and throwout bearing.
Big Block is offline   Reply With Quote
Old 04-29-2007, 12:52 AM   #5
sjarrett71
sjarrett71's Avatar
Farm supply stores are a good source for springs like the one you will need.
-Scott-
sjarrett71 is offline   Reply With Quote
