Old 04-23-2007, 02:02 PM   #1
manimal
manimal's Avatar
Bed Wood
Anybody using anything other than pine or oak in their beds? can you post pics? I have a friend thats a cabinet maker and suggested Mahogony. Isnt that a hard wood also?Thanks in advance.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 04-23-2007, 02:08 PM   #2
ToddSS
Re: Bed Wood
White ash will save you about $80 or so over the cost of oak and looks pretty similar and is very hard.
Here are a couple of pics. One showing the wood with the stain and without and of the finished product.
1968 C10 SWB
ToddSS is offline   Reply With Quote
Old 04-23-2007, 02:12 PM   #3
manimal
manimal's Avatar
Re: Bed Wood
WOW!! Looks great!
-Lance
Old 04-23-2007, 02:18 PM   #4
shifty
Questionable
shifty's Avatar
Re: Bed Wood
This is one of those times when the search feature at the forum is your friend.
Here, I searched for 'wood varnish' and pulled up these threads:
http://67-72chevytrucks.com/vboard/s...t=wood+varnish
I'm sure there are plenty of others that could be found using a different search term like 'wood strips' or 'wood plank' (search doesn't work on 3-letter words, so 'bed' won't get you anything).
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-23-2007, 02:36 PM   #5
cdowns
cdowns's Avatar
Re: Bed Wood
mahogany is considered a soft wood a bit harder than most pine alot softer than most oaks// it could be used for a bed floor and would look good on a lightly used truck but wont hold up to severe work conditions
Old 04-23-2007, 05:26 PM   #6
KAILUAZ
King of Rust
KAILUAZ's Avatar
Re: Bed Wood
I have plywood,, I dont think you need any pics hahaha
1970 GMC 2500, 350, TH400, front disks, thats it!
My Pics
KAILUAZ is offline   Reply With Quote
Old 04-23-2007, 05:36 PM   #7
shifty
Questionable
shifty's Avatar
Re: Bed Wood
I bet your plywood looks better than the rotten ass pine that the PO left on my truck.
Worst part is, he just threw planks of wood on the damned thing - didn't even notch the boards properly - and redrilled all of the damned bed supports so now they look like freaking swiss cheese. It's my one major gripe about the work he did to the truck.
Old 04-23-2007, 05:51 PM   #8
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
Re: Bed Wood
As soon as I get to my bed I will be installing Ash.
I work in a carpenter shop here in Germany and the structure of the Ash is my favorite.
I was thinking about being different and using Hard Maple but my "brothers" said go with the Ash.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 04-24-2007, 11:33 AM   #9
Olden Days
Living In The Past
Olden Days's Avatar
Re: Bed Wood
The Ash is a good choice, but birds eye maple would look killer!!
Olden Days is offline   Reply With Quote
Old 04-23-2007, 07:57 PM   #10
dave-68
Re: Bed Wood
Has anyone used cypress? It doesn't rot. I e-mailed Horkey's to see if he does it but didn't get a response back. I'll probably make the boards myself, I just wasn't sure about the mounting holes. GMCPauls website says to drill the thru hole on center of the washer hole, but that didn't make sense to me if you're supposed to use the eccentric washers?
dave-68 is offline   Reply With Quote
Old 04-23-2007, 08:58 PM   #11
355
355's Avatar
Re: Bed Wood
I used Poplar. It stains real nice, has a fair grain, has lasted thru a winter of firewood, cinder block, etc and does not rot. I drilled the main frame holes straight and used carraige bolts with no problem. steve
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2.
355 is offline   Reply With Quote
Old 04-23-2007, 09:11 PM   #12
wyatt earp
Re: Bed Wood
has any one thought of using osage orange? its a tightly grained hard wood here in ohio, has a really nice yellow/orange color(hence the name) when naturally finished. only problem is finding a tree that is straight for more than 6-8 ft, they are normally pretty gnarley. i have seen some archery bow makers use this wood and it sands and finishes great for them. also looks fantastic alternated with black walnut. now that i've said it i think i may have to try it on the '72swb.
wyatt earp is offline   Reply With Quote
Old 04-24-2007, 11:48 AM   #13
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: Bed Wood
If you use Osage Orange, your better cut the tree down, take it straight to the lumber mill, then the planks straight home, mill them, router them, drill them and install them all in about two days or less because once it dries a little it it impossible to work!
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 04-24-2007, 12:32 PM   #14
rlm316
rlm316's Avatar
Re: Bed Wood
Anyone ever tried teak? Had some 5/4 boards given to me and was thinking of trying them in the bead.
rlm316 is offline   Reply With Quote
Old 04-23-2007, 09:17 PM   #15
wyatt earp
Re: Bed Wood
oops,just thought of maybe a birdseye or tiger maple, quite pricey but would look awwwwwwsome!!!!!!
Old 04-23-2007, 09:45 PM   #16
bedsled71
bedsled71's Avatar
Re: Bed Wood
im using ash for mine..
bedsled71 is offline   Reply With Quote
Old 04-23-2007, 10:08 PM   #17
6977chev
Re: Bed Wood
locust ,cedar, and redwood hold up in weather good. but redwood and cedar are both pretty soft and would ding easily. but i'm not sure what the grain of locust looks like when it sawed in to lumber.
6977chev is offline   Reply With Quote
Old 04-23-2007, 10:10 PM   #18
Solver
Solver's Avatar
Re: Bed Wood
I used hickory on my step side. Natural color no stain. Looks alot like oak and seems to wear well
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 04-24-2007, 12:39 PM   #19
OLDIRON69
Re: Bed Wood
Hickory is a very nice hardwood and fairly easy to work, Ash as well, Cypress won't rot, Cedar like Western red as well as Aromatic are both soft, I would say too soft. Hickory,Oak,Pecan are all good choices as far as workability and very beautiful wood! Osage Orange is hard as concrete and will outlast the truck, like said above, cut, mill and one important thing..it has to be properly dried or it will be a total loss (this is true on the drying with any wood you use)
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 04-24-2007, 12:55 PM   #20
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Re: Bed Wood
Osage orange has one of the highest heating values of any wood at 30,900,000 BTU/cord...great for your wood furnace!
Wood selection and finish really depends upon how you are going to use your truck. Work, show or 100 pt. restoration. If it is a 100 pt. you will have to paint the wood either body color a black. I still need to cut a piece to see what GM used in my Longhorn. Nobody thinks about this but the wood selection should also complement the final color of your truck. I really like the natural color of wood under a bright (clear varnish) finish so hate to stain the wood. Having said that...I have seen some really nice transparent stains that allow the natural beauty of the wood to come through but also give just a hint of the background body color to be used as a complement. Don't be afraid to try something different!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 04-24-2007, 04:27 PM   #21
Mrrilla
Mrrilla's Avatar
Re: Bed Wood
I am cutting my own from Black Walnut. Here is a picture after I planned them and cut the width. The grain becomes deeper and overall darkens with Spar Varnish. This is a hard wood also.
Mrrilla is offline   Reply With Quote
Old 04-24-2007, 12:47 PM   #22
faribran
Re: Bed Wood
DAVE-68...
i have used the cypress.... works out pretty good.. it has some small knot holes that come out....the color kinda washed out.. lll try to take some pics..
faribran is offline   Reply With Quote
Old 04-24-2007, 08:12 PM   #23
dave-68
Re: Bed Wood
Originally Posted by faribran View Post
DAVE-68...
fariban, thanks.
What do you guys know about the mounting holes? Is the c'bore for the washer centered on the thru hole?
Old 04-24-2007, 10:25 PM   #24
kxnomore
kxnomore's Avatar
Re: Bed Wood
Nope, the washer countersink holes are drilled 3/16 of an inch forward from the center hole.
The idea is you drill a 1/8" hole centered in the cross sill. Then you measure 3/16" forward from that hole and drill (with a 1 5/8" forstner bit) the countersunk hole for the washer. That hole should be 1/8" deep.
Then you go back and drill again the 1/8" center hole (lined up with the cross sill) out to the 3/8" size for the actual bed mount bolt.
I wish I had pictures, but that's the idea.
kxnomore is offline   Reply With Quote
Old 04-25-2007, 12:50 AM   #25
John Fabris
TOTY 2006
John Fabris's Avatar
Re: Bed Wood
I used Teak in my truck.
Here is two shot of the wood as I got it.
Three shots of the boards (I already cut them down and ripped the grooves)
during the varnishing stage. I coated them 10 times on each surface with a light sanding inbetween each coat.
NOTE that I only got two knots in the wood, and I used them as the two smallest peices...
And one shot of the wood in the bed on the truck...
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
