Old 04-25-2007, 09:28 PM   #1
Bowtie001
Project underway - finally.
Bowtie001's Avatar
Ignition switch to dashboard interface
OK, I know this should be easy - but is it ever?
I have finally wired my new ignition switch. I put it in the receptacle, and then realized that the two tangs broke off - boo hoo. Oh well, I'll worry about that later. hmm... hmm... how does this thing go in the dash now?
OK. I think I am missing some pieces. It's a 72 GMC if it matters. I have what is pictured here plus the circular hole in the dash with the three equally spaced slots around the circumference. Is there a piece or two I am missing? Does that rubber piece do anything? Does anyone really know what time it is? Does anyone really care?
Thanks in advance.
-Brian
1972 GMC Pre-resto... awaiting allocated funding.
Bowtie001 is offline   Reply With Quote
Old 04-25-2007, 10:45 PM   #2
lbpd719
Zappaphile!
lbpd719's Avatar
Re: Ignition switch to dashboard interface
I haven't done this replacement, but will reply to move your thread to the top (and if its answered, I will know for when I do mine)
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 04-25-2007, 11:01 PM   #3
brak
brak's Avatar
I have edited your pic to help with the assembly process.
first things first. Remove the lock cylinder from the switch. put the key in, rotate it to the left, insert a paperclip into the hole releasing the lock, turn further to the left and it will pull out attached to the key. putting the switch in a vise will help this process.
Ok, now for assembly.
Piece #1 is the ignition switch, place the spacer (#2) over the switch, the big end mates with the dash. hold the switch and spacer up on the backside of the dash with one hand, and then screw on the bezel (#3).
at this point all you need to do is tighten the bezel, and reinstall the lock cylinder. also, it usually helps to connect the switch to the harness before you mount to the dash, but not necessary.
hope that is clear enough.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 04-25-2007, 11:10 PM   #4
brak
brak's Avatar
Actually, I missed the fact that you have a 72...
The spacer and bezel do not look correct for the 68-72 model pickups. Judging by the pic that bezel (#3) is for a 67. I may be wrong about the spacer (#2) but it looks too shallow.
The instructions i posted are correct for your model year, but the bezel should look like the following.
Old 04-25-2007, 11:21 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
I think he has the correct spacer but he doesn't have a bezel. I don't know what the rubber piece is for. The bezel is the chrome piece in Brak's pic. I have included a couple of pictures of the assembly apart and together. Be careful screwing the bezel on, it has fine threads and is easy to cross thread.
LockDoc
Leon
Old 04-26-2007, 08:05 AM   #6
Bowtie001
Bowtie001's Avatar
I think that you guys have the correct idea - I am missing the bezel. Does anyone have one laying around that they could donate to the cause? There are not many boneyards around here, so it's going to e a touch thing to find.
Thanks for the help, if anyone has any leads on getting one, let me know!
-Brian
Old 04-26-2007, 12:33 PM   #7
LockDoc
LockDoc's Avatar
You can get one from about any parts vendor. they are 5 or 6 bucks new. You probably couldn't buy one from a junk yard for that and it will be nice and shiney.....
http://67-72chevytrucks.com/vboard/showgroups.php
Scroll down to the vendors section...
LockDoc
Leon
Old 04-26-2007, 01:55 PM   #8
Bowtie001
Bowtie001's Avatar
Yeah, you are probably right... the only problem is that once I do that, I'll want to do the ww bezel and then maybe the headlight switch rod thingie... oh the humanity. Read my signature, and then laugh because I'll have to get the 5 + 8 s&h approved by high command before purchase.
Thanks for the help though... This stuff is hard to figure out when you may have extra or missing parts.
-Brian
Brak just noticed that you have only 2nd and 4th gears - we should team up - my POS dd only has 1st, 3rd and 5th. I think I just lost 1st though, and reverse ain't so hot either...
Old 05-03-2007, 08:01 AM   #9
Bowtie001
Bowtie001's Avatar
I just got my new one in the mail yesterday - but thank you very much for thinking of it for me.
I have been driving the truck all week, and so far it's been fun having all of the gears you're supposed to have. Hopefully I'll put that bezel in tomorrow when things slow down a bit.
Old 05-03-2007, 11:06 AM   #10
Bowtie001
Bowtie001's Avatar
Another related question (sorry to hijack my own thread)
How does the headlight switch mount to the dashboard? I removed the knob (yes, the right way), centered the switch behind the dash, screwed in that nut-like thing and inserted the knob. Works great, except when the headlights are off the knob sticks out like 2-3". Do I have an incorrect knob or am I missing some sort of spacer?
-Brian
Old 05-03-2007, 03:58 PM   #11
LockDoc
LockDoc's Avatar
If the headlights go on & off OK I would say that you have the wrong Knob/shaft for the switch.
On mine, from the base of the knob to the end of the shaft is 3"....
LockDoc
Leon
