04-26-2007, 01:02 AM | #1 |
BB Harmonic Balancer Timing Pointer Issues
I've been strugling with a bunch of issues. The 454 that came in my truck had a flat cam lobe which obviously caused lots of issues. The other issue I had when it ran was that the timing would not let the motor even run until I got it to 16 degrees. So I installed a new cam and when I brought the motor up to TDC, the timing mark on the balancer points at .... 16 degrees. I've not done this before but I assume it should point at 0 (TDC).
So, are there different balancers for the different years of 454? The balancer I have looks like the original one and looking from the front, the timing channel (line) is about 8 degrees counterclockwise from the keyway. Are there different pointers for the different years? The pointer I have is a cheesy chrome aftermarket unit and 0 degrees is very close to where the timing cover raises out to clear the gears. Or am I just mistaken regarding the timing pinter lining up with the balance line at TDC? Any feedback would be appreciated. Thanks, Whit |
04-26-2007, 01:05 AM | #2 |
GEARHEAD
Re: BB Harmonic Balancer Timing Pointer Issues
I'm not real sure on BBC's but, I would almost bet there are different one's as is the case with SBC's
BTW Do ya maybe want this thread moved to engine and drivetrain forum???? You will get more answers there.
72 SWB 2WD MY PROJECT 72 LWB 4X4 FUTURE PROJECT SUBSCRIBE HEREBOARD VENDORS HERE NORWOOD MEET SURVIVOR! Last edited by RACINJASON22; 04-26-2007 at 01:06 AM. |
04-26-2007, 09:03 AM | #3 |
I do believe when the piston is at TDC the timing mark should be on 0.
If its not mabey the outer ring on the balancer has sliped. Or the timing chain is real slopy or has jumped a tooth. But since you changed the cam, i assume you put a new timing chain on. So thats probley not it. I would bring it up to TDC and put a mark on the balancer at 0 and tune from there. Mabey get a new balancer. Just some food for thought...
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
04-26-2007, 10:25 AM | #4 |
big blocks are common for the balancer ring to rotate and the mark is out, thats why i powertime for the best result
04-26-2007, 10:42 AM | #5 |
When I had my 402 I just timed it by ear. Once I got it where it ran the best, I used the timing light. The mark on my balancer would come up around the 12 o'clock area, with my timing pointer in the 2 to 230 region. I think it is safe to say it had slipped a little.
Caleb |
04-26-2007, 11:52 AM | #6 |
Regarding the outer ring slipping on the crank. Should the keyway in the crank line up exactly with the timing line on the outer ring?
And how does an aftermarket balancer work. Are the original balancers all balanced the same or are they balanced differently? I assume that GM wouldn't do real assembly balance but that they might match parts based on some rough weight calculations. Thanks, Whit |
04-26-2007, 12:35 PM | #7 |
Here is an easy way to test to see if marks are right. Line up the bal. mark with 0 on timing tab. Remove #1 plug. Put a straw in plug hole until it touches piston. Turn engine (by hand). If straw starts to go down your marks are right.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
04-26-2007, 12:54 PM | #8 | |
Thanks, Whit |
04-26-2007, 10:24 PM | #9 |
A foolproof way is to do this:
1--remove #1 plug (best to remove all so motor will turn easy) 2-- make or buy a piston stop 3--turn motor SLOWLY until it hits stop 4--make mark on balancer at 0 mark on tab 5--turn motor back the other way until it hits stop again (SLOWLY) 6--repeat #4 7--1/2 way between these marks will be the exact TDC for #1
04-26-2007, 10:37 PM | #10 |
has the bottom timing gear been installed in the stock key slot
most after market gear sets have atleast 3 keyway slots some have more. adv reg retarted ? |
04-29-2007, 08:02 PM | #11 | |
Thanks, Whit |
