04-23-2002, 11:43 PM | #1 |
Rear Leaf Spring Drop?
Has anyone installed a diffrent rear shackle on the rear leaf spring to drop the back a little? Does anyone make the longer shackles? I realize you can't go much without a "C" notched frame, but I'm only looking for a couple inches. Darren
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
04-24-2002, 04:44 AM | #2 |
Early Classic has them that is were I got mine they are a link to them on the home page of the board.
------------------ 67 GMC Stepside(UNDER CONSTRUCTION) 67 GMC Custom 67 Chevy C-30 |
04-24-2002, 11:07 AM | #3 |
Got 20's????
They are $59 new and lower you between 1.5 and 1.75" is all.
------------------ 72 Chevy C/10 87 Chevy Silverado 4X4 www.geocities.com/chevylwb/chevylwb.html Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
04-24-2002, 10:27 PM | #4 |
Anyone else know of any other companies that make rear leaf lowering shackles? Darren
04-26-2002, 07:39 PM | #5 |
TTT
Hello? Anyone out there? Darren
04-26-2002, 08:45 PM | #6 |
Got 20's????
nobody makes any that go lower if thats what you want. How low do you want to get. I have done extremely large amounts of pulling leafs for different ride heights if you want help.
04-26-2002, 11:10 PM | #7 |
72,
Thanks for the offer. I was just wondering if there were any other shackle manufacturers. I only want to drop between 2 and 3 inches in the rear. I understand this will make it so I can't haul much in the back. That is ok with me however. Darren
04-26-2002, 11:19 PM | #8 |
I've got a leaf rear end also and have been wondering about this as well. 72chevylwb I'm interested tell me more. I've gotta do something until I bag it.
'72 C-10 '99 Silverado '91 S-Dime |
04-27-2002, 09:36 AM | #9 |
You can remove the flat helper,that should be worth 1/2" alone,& combined with a shackle,you should get a couple inches of drop. If more drop is wanted,you might loose 1 or 2 of the bottom short leafs(this will be experimental),& I would reccomend a set of custom slapper bars to control wheel hop. Good luck........69 longhorn.
http://community.webshots.com/user/hotrodhorn |
04-27-2002, 08:33 PM | #10 |
If you have the 2 1/2" wide springs (4x4's and I think Longhorns) then you can use the 73-87 shackles, other than that, Early Classics is it for 2 1/4". They are a great company and I would buy theirs even if they were twice as much as anybody elses.
------------------ 70 GMC 3/4 ton Sierra Grande 402/TH400 72 Jimmy 4WD 4spd 4" & 35's 64 Corvette Coupe 68 Camaro 'vert TPI & TH700 69 Z/28 355 12.6's @110 72 Datsun 240Z-ol' reliable
04-27-2002, 11:27 PM | #11 |
Thanks guys! Good info.
Darren ------------------ Darren Washougal, Washington darrengale67@hotmail.com 1972 GMC C1500 (Bone Stock) Looking for a 72 SWB 4X4 Or 2WD Automatic with little or no rust.
