Old 04-28-2007, 01:26 PM   #1
Texas1971
Anyone used rubber plugs in place of metal freeze plugs?
Just removed a bad metal one from '68 327 and wondered if I could use one of the rubber expansion plugs in its place. The kind that has the nut in the center that expands as you compress it. Anyone had good luck with this? Y'all have been great with the advice as I've been slowly moving along!
Texas1971 is offline   Reply With Quote
Old 04-28-2007, 01:45 PM   #2
airdale94
airdale94's Avatar
Re: Anyone used rubber plugs in place of metal freeze plugs?
I tried one once and blew it out. I might not have got it tight enough though.
airdale94 is offline   Reply With Quote
Old 04-28-2007, 01:53 PM   #3
Texas1971
Thanks. I know they are 1 5/8" so I got the plug that expands up to that. The next size starts at 1 5/8 and goes up to 1 3/4. I guess I can try them both. Any thoughts appreciated.
Old 04-28-2007, 01:53 PM   #4
sodak69c10
sodak69c10's Avatar
i guess i have never used the rubber ones but i have put plenty of block heaters in before they work the same way and they stay in, (i wonder if a person can loctite the bolt to help keep them tight?)
,Clint
LOUD PIPES SAVE LIVES
69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA
sodak69c10 is offline   Reply With Quote
Old 04-28-2007, 02:07 PM   #5
fine69
fine69's Avatar
They work well. Several of them in my 67 Cougar right now. Just make sure they are all the way in before you tighten them down.
Used them for years.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 04-28-2007, 02:45 PM   #6
Texas1971
Hey Fine69! Did you put any silicone on 'em? I like the locktite idea.
Old 04-28-2007, 07:57 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I had opposite results. Mine always popped out.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-28-2007, 08:01 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
while the comparison to block heaters holds water(no pun intended) I have had to replace several of the rubber ones over the years turning wrenches... probably 3 or 4 a year.
Why don't you want to install a new steel one... or better yet, brass?
What ever you do, if it rusted out, there's probably gobs of rusty sludge in there, try to get as much of it out.
Old 04-28-2007, 10:47 PM   #9
truckdude239
truckdude239's Avatar
i agree i pulled one out of a 402 that we are rebuilding in class and it was rough why no take the time to flush the block and install a new steel plug i use red locktite on my plugs always worked well
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-28-2007, 11:15 PM   #10
AuggieStyle
AuggieStyle's Avatar
bought an 87 ram charger in 93 that had a bad freeze plug. I replaced the freeze plug with an expanding rubber one, my dad laughed said it wouldnt work well it sorta didnt I had to replace the freeze plug 3 years ago so eleven years was the limit. for mine.
AuggieStyle is offline   Reply With Quote
Old 04-28-2007, 11:36 PM   #11
grayw0lf
Been there, done that. I made it super tight when I put it in. It held for 3 years.
They are good in pinch, but I'd definately recommend metal.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 04-29-2007, 02:40 AM   #12
rwgregory
In my opinion, the rubber expansion plugs are fine to carry in your toolbox in case you blow a freeze plug on the road. They will definately get you home where you can replace it with a metal one. Let me share a trick I learned from a retired mechanic when installing metal freeze plugs. Coat the outside of the plug with aluminized spray paint. The wet paint will lubricate the plug to help drive it in easier and after the paint dries it will act as a sealer and rust inhibiter.
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 04-29-2007, 03:21 AM   #13
GREASEMONKEY72
GREASEMONKEY72's Avatar
ill have to remember that
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
