04-30-2007, 11:22 AM | #1 |
How long for warm-up?
Now that everyhting is fuel injection, including my motorcycle, I seem to have forgot about warm-up cycles. Here's my question- how long does it take you guy's trucks to take throttle? My truck starts/idles fine, it just a little fussy for about the first 5-7 minutes. I have a GM performance crate engine w/ a holley and headers. Obviously all the old hot-air stoves are not on.
I'm pretty-sure I have the carb dialed in okay. Gas just dribbles out of the sight glass when I open and the electric choke seems to be closing/opening okay (I'm in Austin Texas- it never gets that cold here). It just seems to stumble when I moderatley lay on gas. if I punch it- it has no problem. We're talking about after 5 minutes of driving... My temp gauge says things are all warmed up in the engine, but I'm wondering if it just takes more time to get all that steel and aluminum up to temp to properly atomize the fuel. Before I start tweaking things, I thought I'd ask for your experience. |
04-30-2007, 11:44 AM | #2 |
Re: How long for warm-up?
Ahhh gotta love carbs. I'd say just feather the throttle until it gets warm enough and drive it. That's the joys of a carbed engine. Sometimes they don't run for crap until the engine is warm. I used to have a truck that started and ran with no problems at all every time. It was a 68 c-10 with a 250. All factory, manual choke and all. Didn't even have to use the choke a lot of times in winter. I swear every vehicle has it's own personality.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
04-30-2007, 12:11 PM | #3 |
67 is sold
If it takes more than a couple of minutes, something needs adjusting
04-30-2007, 12:16 PM | #4 |
My K5 takes me working the throttle a little bit for about 20 seconds on a 55 degree morning like today - then it will idle just fine. 5-7 minutes sounds way too long. My K20 will fire right up and doesn't take any warming up on a nice day like today to idle and drive fine. In 20 degree weather I do have to keep working the throttle for about 1-2 minutes before it will idle on it's own.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 04-30-2007 at 12:18 PM. |
04-30-2007, 01:00 PM | #5 |
i have a demon 850 with no choke or anything and i just turn the key... its like driving a fuel injected vehicle in this texas weather. like the others said 5-7 minutes is way too long
04-30-2007, 01:06 PM | #6 |
There is a big diference between idle fine and able to take a dead stop floor stab also. Mine is drivable with no choke in a few minutes. but it takes a little driving before it is ready for a dead stop burn out.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
04-30-2007, 01:06 PM | #7 |
Where's my beer?
I think a truer statement has never been said than whoever mentioned every vehicle is different. Every one of my vehicles is carbureted and they all do a little different.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
04-30-2007, 01:43 PM | #8 |
Old Duffer
I suspect your experiencing a none-heated intake manifold. I put a crate Vortec in my short bed, and on chilly AM's it would run pretty rough at idle for a long time. I swapped the intake for a heated unit and the problem went away. Seems the atomization at idle gets re-condensed on the cold intake passages and dribbles into the cylinders causing the roughness. At speed it doesn't happen because the fuel vapor is moving pretty fast and doesn't have time to re-condense.
My $.02
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
04-30-2007, 01:55 PM | #9 |
Sandwich: Club
I've had the same issues since I swapped my old single plane Weiand intake for a Edelbrock dual plane- i.e. stumble off-idle for about 5-10 mins when cold(idles fine, just stumbles off the line for awhile). Since you're in Austin I doubt it is a cold weather issue.
Richening up the idle mixture screws helped me as every once in awhile I was getting a lean backfire mixed in w/ the stumbles. Also have been playing around w/ carb tuning- installed a 1" phenolic spacer and all of the off-idle issues went away- it's a LOT more drivable while the engine warms up. Problem with the spacer is that I lost some accel. power so now I'm screwing around w. carb jetting to see if I can get more out of it. anyways |
04-30-2007, 04:40 PM | #10 |
I just fixed this problem on a buddy's Street Avenger, kind of by accident. We were trying to eliminate a slight hestitation. Changed to the correct power valve, no help. Change accelorator pump cams, some help but not quite right. Called the Holley Tech Line, and the guy (Ricky) said to look into the primary bore, barely move the throttle linkage, and gas should squirt from the nozzle instantly upon the slightest movement the linkage. If not adjust the accel. pump linkage until it does. It didn't, we did, and fixed not only the slight hesitation, but also the sluggish warm-up. He can now start his truck and take off before oil even has time to hit the valvetrain good. I guess I got lucky on my Street avenger, and didn't experience either of these issues. And the whole thing on his took us about 2hrs to do. O'Rielly's even had the Power Valve in stock.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
