Old 04-30-2007, 01:34 PM   #1
rikyric
rikyric's Avatar
Question for you guys with 6 inch lifts
Did you have to lengthen your drives shafts? Please post year and brand of lift if you did. I cant remember if i read here that you did or did not have to.
I am looking at the Skyjacker 6 inch all front and rear leaf system, or the Tuff Country leaf system.
My Blazer is a 1971, not sure if it is a 52in or 56in rear leaf either?
rikyric is offline   Reply With Quote
Old 04-30-2007, 01:52 PM   #2
Critter
Future TOTM Winner
Critter's Avatar
Re: Question for you guys with 6 inch lifts
In general terms...Yes and No. The back is usually fine, but the front usually needs to be a little longer. I can't comment on exact brand specifications, but this seems to be the general rule of thumb (other members are bound to jump in with details). My 72 K5 had 6 inch springs and rear lift blocks when I got it (not sure of the brand), but the PO didn’t install the front drive shaft because it wasn’t long enough. Some people recommend a transfer case drop kit to help with this, but I prefer a custom built driveshaft with the proper CV joint at one end.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 04-30-2007, 01:53 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Most likely you will have to have the driveshafts lengthened. My '69 had a 6" lift installed by the PO and the driveshafts were lengthened.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-30-2007, 05:40 PM   #4
jojotonka
jojotonka's Avatar
Well, I put on a Tuff Country 6" lift on my 72 Jimmy. Blocks in the rear. The lift came with 1" spacers to lower your transfer case. Both of my driveshafts are completely stock and work properly. Granted I'm not a big off-roader, but I've ran it hard on the sand dunes a couple times. Everything is fine. I fit 37" swampers on 12" wide rim.
jojotonka is offline   Reply With Quote
Old 04-30-2007, 06:17 PM   #5
rikyric
rikyric's Avatar
Hmmm I have heard alot about dropping the transfercase. Anyone have a writeup or pics?
Old 04-30-2007, 06:26 PM   #6
Critter
Future TOTM Winner
Critter's Avatar
Well, so far you have 3 choices:
A. Lengthen both
B. Neigher need to be lengthened
C. Lengthen front only
Clear as mud, right?
Old 04-30-2007, 06:35 PM   #7
rikyric
rikyric's Avatar
A. Lengthen both
Exactly what I was thinking
Wonder why there is so much variance
Old 04-30-2007, 06:51 PM   #8
jojotonka
jojotonka's Avatar
Well, I guess it depends on how much of a perfectionist you are. When I say, I had to do nothing to my driveshafts. It's true, however, you can see about an inch of the spline on both shafts.
Now thats probably a sin to some guys, but unless your a hardcore off-road guy thats pushing your equipment to the max, I've never had a problem.
Old 04-30-2007, 06:22 PM   #9
1969k10stepside
It should have 52" rear springs.I installed a 6" Rough country lift on mine.Its actually 6" rear,and 4" front.Not the best lift kit,but at $625 for 4 new springs,I went for it...might upgrade later
1969k10stepside is offline   Reply With Quote
Old 04-30-2007, 09:54 PM   #10
BAD4X4
BAD4X4's Avatar
I just put a 6"in my blazer last week, It's a superlift. I bought it from 4-wheel parts. They have great prices. The only thing I did was steering arm and longer brake lines. Hope this helps.
1972 Cheyenne K-30 6"lift {502 PROJECT}
1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue}
1972 Cheyenne K-20 Custom Stretch 6" lift 454
1972 Custom Deluxe K-20 4" lift
2007 GMC Crew Cab Diesel 6"lift {The Tow Rig
2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's)
1977 El Camino SS Grandpa baught new
1986 K-30 Crew Cab 502
1955 Chevy 2-Door gasser 454 550hp{project}
1956 Chevy Bel-Air 2-Door hardtop 572 700hp
1979 Ford F-350 All Original 4x4 (Wife's)
BAD4X4 is offline   Reply With Quote
