04-30-2007, 06:46 PM | #1 |
Exhaust help!!! Please show-off your dual exhaust pics of C-10 2wd SWB!!!
I just went from a 250 6cyl to a 460 BBC in my '68 SWB and am really not sure how to route the exhaust because of that crossmember that the rearend trailing arms bolt to. It looks like if I cut out holes so the pipes would go through, it might weaken it. Any pics of the underside of your truck showing off your cool dual exhaust would be greatly appreciated. Thanks!!!!
04-30-2007, 07:01 PM | #2 |
Re: Exhaust help!!! Please show-off your dual exhaust pics of C-10 2wd SWB!!!
Not sure about this idea , but somebody here would know .
how about welding in some short heavy walled pipe in that x-member so the exhaust passes thru those pipes ??? the day will come I'll be in your shoes
"I feel the need for speed!"... as soon as I am done with my nap. |
04-30-2007, 08:16 PM | #3 |
69fatmotor
i cut out a hole on each side and inserted a piece of 4" pipe in the crossmember for the exhaust to go through heres a few pics .
05-01-2007, 11:21 PM | #4 |
mike nutt, that looks really good. I'm hoping to get some exhaust put on my 71 GMC this week. First comes the alignment and then comes the exhaust. i like the idea about the 4" pipes welded into the cross member.
__________________________________ 1971 GMC Stepside 350HO Deluxe 330hp, TH350 w/Gear Vendors, 3.73 Eaton posi, Fitech EFI, Boyd's Welding Tank, Ridler wheels, ECE 4/6" drop, front/rear sway bar ________________________________ |
05-02-2007, 10:21 AM | #5 |
Next project: 1970 K10
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 05-02-2007 at 10:22 AM. |
05-03-2007, 12:53 AM | #6 |
[QUOTE=glock35ipsc;2154873]
QUOTE] by moving the muffler closer to the header like this. will that make it louder or not ???
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
05-02-2007, 01:49 PM | #7 |
that's some *****in' exhaust Bob!!!!
Guess the mistery is over about whether or not to go through the crossmember |
05-02-2007, 02:49 PM | #8 | |
If not, they can be cut with a jig-saw or a sawzall. And the reinforcement piece can be bolted in if necessary. There are a number of different ways of doing this. Mike used pipe on the inside of his cutout. I used 1/4" plate that I cut into circles, cleaned them up on the lathe and welded to the outside face of the member. The most important thing is to add some method of reinforcement to the member once you are done, either welding or bolting. I don't think either the way Mike or I did it it is "moe betta" than the other, it's just a matter of personal preference, and usually the materials available. Just the idea of doing odd little things like this to add that custom touch is what I like!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 05-02-2007 at 02:54 PM. |
05-02-2007, 06:45 PM | #9 |
67-72 Addict!
Those trucks look great!. I would love to see some trucks done this way using headers instead of manifolds.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
05-02-2007, 02:24 PM | #10 |
On the fast track to nowhere..
Here's a FAQ on how to do it.
http://67-72chevytrucks.com/vboard/s...d.php?t=201474
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
05-02-2007, 02:44 PM | #11 |
If you don't want to do all that work makin your own, Early Classic Enterprise (I think) makes a bolt on crossmember that has the exhaust pipe holes cut in it already.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
05-02-2007, 08:07 PM | #12 |
There is a company that sells a new cross member for these trucks with holes for exhaust precut in it. I cant remember who it is though for some reason I'm thinking early classic. I might be wrong though
05-03-2007, 12:40 AM | #13 |
ECE & CPP both sell the crossmember you describe & ART has a tubular version that offers better exhaust clearance (than factory).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-03-2007 at 12:41 AM. |
05-03-2007, 12:59 AM | #14 |
you can run it through the crossmember which isnt hard to do with the right tools
or you can dump the exhaust before the crossmember mine dumps out right at the back of the cab just under the bed
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
05-06-2007, 12:08 PM | #15 |
Just put on new exhaust - Hooker long tubes, 2.5" piping, IMCO Flowtech mufflers, exits out of the back corner. I think I am going to trim up the exhaust ends a little bit so you can see them from the side.
