Old 05-01-2007, 05:27 PM   #1
shadaway
Full Blown Rookie
shadaway's Avatar
A Nudder Nube Question
Keep in mind, learning as I go.
Stock 350.
Adjusting the valves as they are rattling pretty good. I've got the service/shop manual and it basically lays it out step by step with one minor fact missing. How do I identify which valves are for Intake and Which are for exhaust. Also, I am assuming the following pattern for identifying the valves for cylinders 1-8
1 is 1st right when facing the motor from front of truck
2 is 1st left when facing the motor from front of truck
3 is 2nd right when facing the motor from front of truck
4 is 2nd left when facing the motor from front of truck
etc etc etc . Am I correct on this?
Now, if anyone knows which valves are intake and exhaust, stock heads, stock exhaust etc.
shadaway is offline   Reply With Quote
Old 05-01-2007, 05:33 PM   #2
john
member #16
john's Avatar
Re: A Nudder Nube Question
With your valve covers off, just look at which valve lines up with each intake and exhaust port on the int. and ex. manifolds.
Cyls 1 3 5 7 are on the drivers side 2 4 6 8 pass side. Parts are designated by driver side or pass side.
john is offline   Reply With Quote
Old 05-02-2007, 09:40 AM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
A pic to go with the words.LOL
sneakysnake is offline   Reply With Quote
Old 05-01-2007, 05:34 PM   #4
bad72c10
bad72c10's Avatar
Well, look at the heads, and find the valves that line up with the ports on your ramhorns or your header tubes, and there's your exhaust valves. Hope this'll help you out there. Justin
'72 C/10 SWB 355/ broken TH350 and 3.07s Soon to be 355/700r4 and 3.73s
bad72c10 is offline   Reply With Quote
Old 05-01-2007, 06:40 PM   #5
shadaway
Full Blown Rookie
shadaway's Avatar
Got it.
Yeah, that was too easy.
It was a test. To see if you guys knew.
Thanks.
Old 05-01-2007, 07:45 PM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
Originally Posted by shadaway View Post
Got it.
Thanks.
No it wasn't---Or you would not have asked.
Old 05-02-2007, 09:02 AM   #7
Luvlegs
Luvlegs's Avatar
HAHAHAHAHAHAHAHAHA I love it... "Now that there was funny - I don't care who you are..."
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
