Old 05-05-2007, 10:49 PM   #1
BaddBusa2005
BaddBusa2005's Avatar
Rear Window Rust
Is there any good way to fix rust around the back glass?? I have a few spots on the top and one spot starting on the bottom driverside corner
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
Old 05-05-2007, 11:35 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: Rear Window Rust
sand and prime paint. unless it worse then i guess id have so make the pieces and weld them in.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 05-06-2007, 12:03 AM   #3
BaddBusa2005
it snot through yet, I am going to have to take the window out and do as said. POR15 is my frend i guess
Is this common on these trucks?
Old 05-06-2007, 02:29 AM   #4
bigblock73
yeller
bigblock73's Avatar
If rust has started, the only way to fix it is to sand/bead blast that area, prime and paint. Just sanding will not work, as you cannot get the rust from the pits in the metal....it will come back.
I have not seen a lot of trucks rust in this area...your gasket must be bad as moisture has clearly gotten behind/under it.
bigblock73 is offline   Reply With Quote
Old 05-06-2007, 10:12 AM   #5
Restrorob
The One And Only !!!
Restrorob's Avatar
I agree with Jeff on the blasting to get all rust removed, Small spot blasters can be picked up fairly cheap for this type repair.
http://www.harborfreight.com/cpi/cta...emnumber=93221
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 05-06-2007, 10:59 AM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
i agree with big block73 . As to it being common that depends on where you live and if salt can get in there. I knew a kid who replaced the back window with a slider and didnt seat the gasket right thus causing rust there. make sure the gasket is GOOD and seated properly when you repair this rust. New gaskets arent that expensive as compared to repairing the cab
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-06-2007, 01:27 PM   #7
BaddBusa2005
thanks guys, I actually have a spot blaster. I need to get this aleviated quickly before it gets worse. It has an aftermarket rear slider in it, so I assume who ever put it in didnt seat the gasket correctly. Oh well, Ill take care of it. Thanks again.
Ryan
