Old 05-06-2007, 10:10 AM   #1
65-72 chevytoys
65-72 chevytoys's Avatar
fuel gauge problem
Anyone have their original stock fuel guage go all the way to the right way past full and stay there? The needle is stuck at 90 deg. What happend and what do I need to do to fix it?
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 05-06-2007, 01:05 PM   #2
bedsled71
bedsled71's Avatar
Re: fuel guage problem
mine will do that and stay for a while then after i use alot of gas it goes down.,. never had it stay
bedsled71 is offline   Reply With Quote
Old 05-06-2007, 01:50 PM   #3
65-72 chevytoys
What is causing it? It seems to be stuck at the 3 oclock position.
I know the tank is not overfilled the guauge was about 3/4 of a tank before it happend so I don't think it is a float problem.
Is the guage broken or a wiring issue?
Old 05-06-2007, 02:03 PM   #4
Rupdog
i'm curious about this too. my truck has the same problem, and the tank was bone dry...
i added 5 gallons, and it didn't budge. the previous owner did the rear tank conversion, and i don't know what sender he's got in there.
the truck is still in the body shop, so i haven't had a chance to screw with it.
can someone chime in on this?
Rupdog is offline   Reply With Quote
Old 05-06-2007, 02:09 PM   #5
mnunn454
mnunn454's Avatar
It's got to be one of only a few possibilities:
Grounded or "open" wire going to the sending unit
Bad gauge
Sending unit grounded or open internally somewhere
Wrong sending unit for the gauge (should match re: ohms)
Stuck arm in the sending unit (up or down. I forget which) or sunken float.
I'd test all three areas (gauge, sending unit and wire connecting the two) with a digital voltmeter for grounds and opens.
Let us know what you find.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 05-06-2007, 02:18 PM   #6
Ilike 72"s
I had that problem and found the wire gets damaged where it runs under the cover on your door rocker. It collects dirt, rust and grit that wears off the wire coating, causing it to ground out. Take the cover off, lift and wipe off the wire and watch your gauge. Worked for me.
Ilike 72"s is offline   Reply With Quote
Old 05-06-2007, 02:28 PM   #7
Rupdog
i'll check those. thanks!
Old 05-06-2007, 02:51 PM   #8
MT1972cheyenne
MT1972cheyenne's Avatar
ILIKE72's is right on the money. An open circuit "or key off" will put the needle at or near 9 o'clock, and a grounded circuit will put the needle clear past full to near 3 o'clock.
MT1972cheyenne is offline   Reply With Quote
Old 05-06-2007, 09:09 PM   #9
va_tlc
va_tlc's Avatar
mine was the sending unit. good luck finding one locally i called all 3 auto zone advance an fisher none could get it. but bill at atheys had it in stock i asked that same question a couple weeks ago and someone added a link to mine that has a awsome write up all about the gas tanks and sending units...troubleshooting it and how to check it, maybe someone can find it and link it here
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 05-06-2007, 09:33 PM   #10
northerngmc
northerngmc's Avatar
An excellent tech/troubleshooting article on testing a fuel gauge.
http://www.6066gmcguy.org/Electrical-02.htm
I used it last month on my 69 GMC and it pointed right to the problem.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 05-06-2007, 09:52 PM   #11
65-72 chevytoys
Lots of good info on that site. I added that one to the favorites.
Old 05-06-2007, 10:25 PM   #12
northerngmc
But did you find the problem?
Blaine
Old 05-07-2007, 06:00 AM   #13
va_tlc
va_tlc's Avatar
hey northern thanks alot for that site, it fixed mine right up, was hoping you would see this thread
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 05-07-2007, 11:31 AM   #14
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
The same thing happened to me in my 50' and the 70.' In both cases it was the sending unit. THe conection @ the sender is weak because of it being corroded.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 05-27-2007, 09:54 PM   #15
65-72 chevytoys
finally found the problem it was a break in the wiring from the sending unit behind the seat by the tank. My guage works now but that didn't help when I ran out of gas last weekend. Good thing I was close to home.
Old 05-27-2007, 10:24 PM   #16
GREASEMONKEY72
GREASEMONKEY72's Avatar
that used to happen to me cause the wire was just wrapped around the lead and it would lose connection, so i took the nut off that was there and put a connecter on the wire and srewed it back on with the nut and its been fine since
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-27-2007, 10:44 PM   #17
RyanG
RyanG's Avatar
Have the exact same issue.....replaced sending unit a while ago but that didn't fix it and then I just never got around to looking into it again. I just use a yard tick to see how much gas I have......will investigate further now that truck is in pieces.......lots of great help here....I love this site.
RyanG is offline   Reply With Quote
