Old 05-07-2007, 01:45 PM   #1
arkracing
Weekend Warrior
Arrow Pwr Steering Pump&Brackets, Some AC Brackets, Matching Pulley's etc. '71
All this stuff came off of a SWP V8 '71 4x4 Truck:
I have the Power Steering Pump and Brackets off a '71 - no lines. The pulley doesn't have any bends in it. NOTE: the pump does have play in the shaft - It was on a running truck and worked fine, but I would suggest a rebuild - The brackets are worth more than the pump, so I can take them off the pump for shipping etc. The pump shaft is tight in vertical movement but slides in and out about 1/8". Yeh I know you sickos - I can't figure out how to explain it any more "politically correct"
I have SOME A/C brackets - see the pictures. I know that there are 3 more brackets to complete the set. But hey what do you want? 4 out of 7 wins the series
I have the Alt adjustment bracket - I can't remember how the lower part of the alt. mounts but I don't see the bracket.
I have the 3 matching pulleys - the main Double Crank Pulley, the "Add-On" crank Pulley for Power Steering/AC and the Water Pump Pulley.
I would like to sell everything together @ this point.
I'll start @ $100 + shipping - if you don't like it, make a REASONABLE offer. Oh and this stuff isn't that light - the add on pulley is weighted and the pump is pretty heavy as well.
I see used powersteering pumps go for $50-$60 with the gamble that the pump is still good go for around $50 here on the board I'm telling you that this pump has play
I also have a set of SBC Frame Mounts: $20 + Shipping
and a set of 250 6cly Frame Mounts: $15 + Shipping
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 05-07-2007, 01:58 PM   #2
HuggerCST
HuggerCST's Avatar
Re: Pwr Steering Pump&Brackets, Some AC Brackets, Matching Pulley's etc. '71
I'm interested in the bottom 2 A/C brackets pictured should you decide to split it up.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 05-07-2007, 02:57 PM   #3
jorgensensc
jorgensensc's Avatar
If this is for a SWP I would be interested in the pulleys, minus the power steering pulley shipped to 77018, If you don't mind.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-07-2007, 04:01 PM   #4
arkracing
Weekend Warrior
Shawn
Everything is for a SHORT Pump ^ . As I said above I would like to sell everthing together as it is easier than sending 1 bracket to someone that a pulley to someone else etc.
-'66 C10 Suburban
Old 05-07-2007, 04:46 PM   #5
jorgensensc
I was only asking if you split them up. I figured Huggercst wanted the A.C. brackets, I wanted the pulley, then all you have left is the power steering pump with brackets and pulley, and the Alternator brackets. Just trying to get the pulleys I need (mine are mismatched right now)
Shawn
Old 05-07-2007, 06:25 PM   #6
arkracing
Weekend Warrior
If I can get enough people to split everything up without have leftover then yeh I'll do it.
Sorry guys, don't mean to have an attitude - it's been a rough day
-'66 C10 Suburban
Old 05-07-2007, 06:51 PM   #7
CorVM
If you end up splitting everything up, I wouldn't mind having the alt bracket.
CorVM is offline   Reply With Quote
Old 05-07-2007, 09:50 PM   #8
billsbowtie
billsbowtie's Avatar
i only saw 3 a/c brackets in the pic.s . i would like to make you and offer for the parts in the pic.s of $90.00 shipped to 24281. and i would like a pic. of the sb eng. mounts. thanks
billsbowtie is offline   Reply With Quote
Old 05-08-2007, 08:21 AM   #9
arkracing
Weekend Warrior
SBC Engine mounts - last picture on the right - the are black, very clean looking, no rust/pitting.
-'66 C10 Suburban
Old 05-08-2007, 11:55 AM   #10
billsbowtie
pm sent
Old 05-08-2007, 01:04 PM   #11
arkracing
Weekend Warrior
OK - looks like everything )except for the 6cly motor mount stands) is SOLD to billsbowtie.
-'66 C10 Suburban
Old 05-08-2007, 01:28 PM   #12
HuggerCST
HuggerCST's Avatar
Bill- Keep me in mind if you decide to sell those A/C brackets.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 05-08-2007, 09:08 PM   #13
billsbowtie
wynne i needed the big one on the bottom and maybe the one to the left to make me a set.i will check to make sure. do you need the top right one?
Old 05-08-2007, 11:07 PM   #14
HuggerCST
HuggerCST's Avatar
No problem Bill, I was just trying to complete a set myself, but I'm in no hurry, I'll find them eventually. I don't need the one on the top right. Thanks.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
