05-10-2007, 04:02 AM | #1 | |
Hinges or latch assembly....
Well Im starting to tear my truck apart....starting with the interior. Gettin in and out of it alot...
Im having problems with my door not closing, I have to slam it 2-3 times before it finally closes most of the time. Other times just simply letting go of the door and letting it close its self will work flawlessly. And getting out I have to hold the handle up and hit the door pretty hard to get it to open. I had a similar problem on a buddies Nova, it was his door pins making his door sag and the latch wasnt lining up properly. Are there door pins on our trucks....or is there a way to adjust the hinges. Or is there a chance there could be something wrong with the latch? would spraying a healthy coat of the WD40 on it do anything to help? Thanks, Mitch-
05-10-2007, 04:07 AM | #2 |
Re: Hinges or latch assembly....
try adjusting on the hinges and see what happens and if that dont work then try the latch
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
05-10-2007, 10:32 AM | #3 |
It's a catastrophic success.
Make sure your door is lineing up properly and not dragging other wise the striker is adjustable to get a good fit these trucks dont have pins
