05-13-2007, 12:15 PM | #1 |
tranny ?
does a 700r4 bolt up to and work on a 205 case using the thm 350 adapter and shaft and are the lengths the same or do i need to change mounting locations and shaft lenghts
common sense isn't so common anymore Last edited by wibilly; 05-13-2007 at 12:17 PM. |
05-13-2007, 02:03 PM | #2 |
Member #1049
Re: tranny ?
The 700R4 uses the same bolt pattern as the T350 for the 205 adapter.. the tailshaft is longer on the 700R4.. You can just cut it off if desired or have a trans shop change it out.. The 700R4 is longer between the belhousing mount and the transfer case so you will have to either move the engine and trans forward or move the transfer case and crossmember back and redo the linkage and drivelines
Here is a link to the dimensions for different transmissions http://www.tciauto.com/Products/Tech...bles_print.htm |
05-13-2007, 02:49 PM | #3 |
Re: tranny ?
when I did mine I think it was 2 in longer I used a spacer that goes between the trans and the transfer case I think it was 3/4 of an in thick. I posted the info up here before on were i bought the spacer it was the cheapest and easyest way to go I think I paid 50 for it at the time.
Earl 68 2500 4x4 GMC Burb |
05-13-2007, 02:57 PM | #4 |
Re: tranny ?
try this post here the info on were to get the spacer is posted in this post.
http://67-72chevytrucks.com/vboard/s...d.php?t=128495
05-13-2007, 08:34 PM | #5 |
Re: tranny ?
thanks for the help guys. was thinking about going to the 700 but it's a little late in the game now. i'm nearly ready for final assembly just need to finish engine and install . the rest of the driveline is in and it's in paint. i know i'm gonna want to make other changes but i think i'm gonna put her togather and run her awhile and see what i like and don't then do her again since i started this project i got 6 more so i have different goALS FOR WHAT I WANT IT TO DO thanks again
common sense isn't so common anymore |
