Old 05-15-2007, 11:59 PM   #1
sider68
sider68's Avatar
Repo Fenders
I have a 56 that requires work on both dog legs of fenders.Would i be better spending money on repo or getting someone to fix existing?
sider68 is offline   Reply With Quote
Old 05-16-2007, 09:38 AM   #2
bondobob
bondobob's Avatar
Re: Repo Fenders
If the rest of the fender is cherry then fix it. If it rotted out around the headlights then replace. I went with repos and they don't fit that very well. Not terrible but not perfect. Also the seams around the front are particularily nasty. IMO The place I got them from said to sand ALL the black off because it is not primer.
bondobob is offline   Reply With Quote
Old 05-16-2007, 11:01 AM   #3
northerngmc
northerngmc's Avatar
Re: Repo Fenders
I used reproduction front fenders on my 59 GMC and was very happy with them. They fit decent, the only issue being around the headlights, it required a bit to get the headlight surrounds to fit.
If the rest of your fenders are solid consider fixing them, if not then replace them.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 05-16-2007, 07:58 PM   #4
55ChevyPU
55ChevyPU's Avatar
Re: Repo Fenders
I replaced my passenger side fender, I have a pretty bad fitting issue between the vender and the cab though it sticks out to far and the door wont open properly without me leaving the gap big enough between the two, ill probably end up using some sheetmetal screws to try and pull the fender into the cab a bit more. Other than that it looks great and needs almost no body work.
55ChevyPU is offline   Reply With Quote
Old 05-16-2007, 11:31 PM   #5
sider68
sider68's Avatar
Re: Repo Fenders
The fender supplier told me he sold lotsand they fit great.The fenders are very solid except the dog legs.I did not ask the body guy how much cheaper it would be to replace than fix
Old 05-17-2007, 07:46 AM   #6
2ndGenRR
2ndGenRR's Avatar
Re: Repo Fenders
I agree with the above posts...fix the fenders you have. I have done the aftermarket fender thing and they never fit like the originals. You end up spending just as much or more time fitting (cutting, welding, hammering the heck out of) the aftermarkets as fixing the originals...plus you have the cost of the fenders.
The Stable:
1952 GMC 1/2 ton, 5-window...Owned since age 16...that was awhile ago! Torn apart and waiting for my boys to get old enough to help me.
1990 Chevy K5, 5.3L, 4L60E, slowly going back together as my dune truck.
1951 Chevy 1/2 ton, 3-window...building to sell.
Daily Drivers: 1998 3/4 ton Burb with a 6.5 Turbo Diesel and 1994 1/2 ton Silverado.
I grew up in Flint, Michigan so I can't help but to bleed Chevy!
2ndGenRR is offline   Reply With Quote
Old 05-17-2007, 08:26 AM   #7
larry may
Smile Re: Repo Fenders
Makes one think about if these ole rides get streched or somewhat dialapidated over the years that the new stuff will not fit right? Noticed that the last couple we worked with fittment was an issue.
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 05-17-2007, 08:54 AM   #8
2ndGenRR
2ndGenRR's Avatar
Re: Repo Fenders
I'm not sure about the trucks or panels stretching, but I know that the dies they stamp the repo fenders from are normally the old dies from GM. After about a bazillion hits, those dies start to lose their original shape. In my experience, the lines aren't quite as crisp and you will notice "flairing" (for the lack of a more technical, correct term) of the edges and seams.
The Stable:
