Old 05-16-2007, 11:38 AM   #1
killer71
killer71's Avatar
Is it possible to....?
For all you boys that are cuttin on these trucks, is it possible to turn a swb truck into a blazer and if possible does anyone have pictures? Thanks Killer!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 05-16-2007, 02:22 PM   #2
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
Re: Is it possible to....?
yes but why cut up a shortbox, id cut a longbox down if you were going through the trouble anyway.
milehightoyz is offline   Reply With Quote
Old 05-16-2007, 03:47 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I agree. Sacrafice the easiest and cheapest to get. Are you thinking about keeping the pickup cab or making it open to the bed like a blazer?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-16-2007, 04:46 PM   #4
killer71
killer71's Avatar
I was just curious if it could be done. So it would be easier to do with a LWB?
R.I.P.
Killer 71
10/26/07
Old 05-16-2007, 04:53 PM   #5
Jtrux
I'm a poor spectator
Jtrux's Avatar
It's not that it's easier to do with a longbed but rather it would be easier to find a longbed for real cheap.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 05-16-2007, 05:10 PM   #6
vtblazer
vtblazer's Avatar
Explain your thinking more please.
What do you want to start with and what do you hope to end up with?
Your original question is pretty vague.
vtblazer is offline   Reply With Quote
Old 05-16-2007, 06:28 PM   #7
killer71
killer71's Avatar
Just simply would it be possible to make this look like an original blazer. Just curious as to what it all would entail, make sense????
R.I.P.
Killer 71
10/26/07
Old 05-16-2007, 06:36 PM   #8
Jtrux
Jtrux's Avatar
You would really have to have your mind made up that you wanted to do it or you would end up with a big pile of scrap. Just my 2 cents, but just save your time (actually a lot of time) and buy one.
Old 05-16-2007, 07:51 PM   #9
vtblazer
vtblazer's Avatar
Yep clear now, thanks.
Possible but way far from practical.
Would you keep the same wheelbase? (interesting approach)
If yes on the wheelbase,
* you'd have to change the top portion of the windshield frame.
* make up a 'B' pillar for the door/bedside mating.
* connect the bed/cab floors together to make a one piece unit
* connect the cab/quarter panels together
* cut down the doors. (easiest part of the transformation)
* build an undercarriage that would keep the body/firewall from flexing.
* move the gas tank
* add 6" to a hard top to fit or have a soft top custom made.
If the answer on the wheel base is no and you want it the same as an original blazer.
* all the above plus shortening the frame.
* shorten the rear drive shaft.
* shorten and make fit/work again the rear brake lines and e-brake cable.
That's about what it would take to make it look like an original blazer.
Old 05-16-2007, 08:06 PM   #10
killer71
killer71's Avatar
* move the gas tank
Hmmm. I thought the blazer and the swb truck were the same length????
R.I.P.
Killer 71
10/26/07
Old 05-16-2007, 08:09 PM   #11
vtblazer
vtblazer's Avatar
Nope, GM threw the 6"s into the SWB.
This link should show the frame difference's.
http://www.chuckschevytruckpages.com/framespecs.html
Old 05-16-2007, 05:22 PM   #12
bouncytruck
SKINNY TIRES RULE!
Anything can be done, it just depends on how much time, mone and skills you've got. Check out what Frizzle Fry made from a burb - http://67-72chevytrucks.com/vboard/s...d.php?t=239896
bouncytruck 1972 K5
Old 05-16-2007, 05:44 PM   #13
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
How have I missed that thread
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-16-2007, 06:41 PM   #14
bouncytruck
SKINNY TIRES RULE!
I missed it for a while too. CG posted a link to it. Frizzle Fry has done amazing work that most of us have only dreamed about doing.
bouncytruck 1972 K5
Old 05-16-2007, 05:32 PM   #15
1969k10stepside
I am planing on getting a K5 to conver to 2wd from a member.I was thinking of just using the old frame for measurements and the body mounts and use a 2wd truck frame.If your going to have to cut down the frame anyway,why not use a largely available lwb frame?Thats what I plan to do...
1969k10stepside is offline   Reply With Quote
Old 05-16-2007, 06:35 PM   #16
onetonk5
Cereal Killer
onetonk5's Avatar
I say no....yes it could be done but your gonna need a blazer for donor parts...windshield frame/floor and rear floors, b pillars for sure.
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
Old 05-16-2007, 06:40 PM   #17
bouncytruck
SKINNY TIRES RULE!
You'd be better off finding a 4wd Blazer and converting it to 2wd IMO. If you are going for a complete custom look, it might be ok to start with a PU, but otherwise, you have a lot of work that could be avoided buy just finding a decent Blazer.
bouncytruck 1972 K5
Old 05-16-2007, 06:41 PM   #18
killer71
killer71's Avatar
Thanks guys was just curious. I see all the custom work and wanted to know if it could be done with a pickup frame/box.
R.I.P.
Killer 71
10/26/07
