Old 05-16-2007, 10:16 PM   #1
chevymotocross
chevymotocross's Avatar
Tow Hitch with spare tire?
I soon would like to mount a trailer hitch to my 87 swb 2wd. The factory spare tire mounting setup is still there. I don't have a step bumper and want to keep the bumper I have. Is there anyway to mount a trailer hitch without interfering with the spare tire? I don't want to have to carry the spare in the bed.
chevymotocross is offline   Reply With Quote
Old 05-17-2007, 01:10 AM   #2
tyjoja
Re: Tow Hitch with spare tire?
great question, i've been wondering the same. I just intalled an under the bed spare set up on my 73, and don't see where the hitch would have room to bolt on, but I hope it is possible. thanks bob
tyjoja is offline   Reply With Quote
Old 05-17-2007, 09:17 AM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I have a frame mounted hitch, and the spare is under the bed, so it has to be possible. I don't know anything about the hitch. It was on the truck when I bought it.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 05-17-2007, 09:30 AM   #4
bigblock73
yeller
bigblock73's Avatar
Most hitches bolt to the frame rails, and the spare sits between the rails...so you should be fine with pretty much any frame mounted hitch out there.
BTW - Welcome to the board from MN.
bigblock73 is offline   Reply With Quote
Old 05-17-2007, 10:37 AM   #5
neverfinished
The only problem I've had in the past was with a short bed truck and a hitch designed to hide behind the bumper. Everything fit well side to side but the spare hit the cross member that the receiver was welded to. A smaller tire may have fit but the problem was more an issue of how the hitch was built. It sat way back behind the edge of the bed and had a longer receiver.
neverfinished is offline   Reply With Quote
Old 05-17-2007, 06:02 PM   #6
chevymotocross
I'll have to check into this more, I have a Reese hitch mounted to my 78 ford that fits chevy as well with different brackets, I may just pull it off and try mounting it to the chevy. Bigblock73, your photo icon of the chevy racing trucks, is that from Nascar truck racing from the 80's?
Old 05-17-2007, 07:52 PM   #7
bigblock73
yeller
bigblock73's Avatar
Here you go
http://www.73-87.com/7387info/Circle_Track_7387.htm
Old 05-17-2007, 06:44 PM   #8
Eyegore
What Hump?
Eyegore's Avatar
My box hitch is attached to my step bumper, true I cannot haul a huge trailer with it, but a smaller 5 x 12 maybe, and that depends what's loaded on it. Remember though it's not what you can haul but how you stop the load your towing, you may need a trailer brake.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 05-19-2007, 08:19 PM   #9
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
I have a Reese Class III or IV receiver mounted under the frame of my truck. Although, it's a tight fit, the spare tire sits in the original location. Only mod I made was to relocate the long threaded carrier bolt that holds up the spare tire by using 1/4" plate steel. The plate steel replaces the 1/4" spacers use between the frame and the receiver. (The pic is deceiving. It makes the steel plate look off-kilter. It isn't, but the carrier bolt is - slightly.)
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
