Old 05-16-2007, 10:42 PM   #1
1969k10stepside
Shorten truck frame or convert blazer frame to 2wd?
Ok,so I'm working on a deal for a blazer tub and the frame comes with it...The bad part is that the frame is toast.There is another frame that could be used but I was also considering just shortening a 2wd truck frame.
So... y'all think I would be better off trying to convert the 4wd blazer frame to 2wd,add a rear coil suspension and bolt in a 2wd front suspension or....Take a 2wd truck frame,shorten it,add the blazer body mounts and then the chassis portion is complete enough that the tub can go on?
Now....I have the tools to make it happen either way but which do you think would be better/easier?
1969k10stepside is offline   Reply With Quote
Old 05-16-2007, 10:44 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Shorten truck frame or convert blazer frame to 2wd?
I would think converting the 4wd would be easier.
That said, I would love to see you shorten the 2wd pickup frame and add the Blazer mounts. That would make a great FAQ thread.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-16-2007, 10:45 PM   #3
BOSS
Just here to help
BOSS's Avatar
What frames do you have?if you just have one then go that route
Support our site
Norwood Survivor
BOSS is offline   Reply With Quote
Old 05-16-2007, 11:00 PM   #4
1969k10stepside
Neither yet.There is the one under it that is toast,and then I have the option of getting another 4wd Blazer frame to use.Why oh why did I get rid of my extra 2wd truck frame...So,if I was going to use a truck frame,I would have to get one from a local junkyard. So,no matter what I have to buy one..Its just a matter of cutting,shortening,welding it,etc or converting the blazer frame,drilling holes,bolting in crossmembers,etc
Old 05-17-2007, 10:15 PM   #5
1969k10stepside
Well,tomorrow I'm going to the junkyard to price a frame to use.Not just going to get the frame though,the whole chassis.Also going to look at a '67 front clip to possibly use..
Old 05-17-2007, 11:25 PM   #6
oilyrag80
oilyrag80's Avatar
Convert the 4x frame its much eaiser me and 2 friends completed a 4x4 to 2 wheel drive conversion in 1 saturday
oilyrag80 is offline   Reply With Quote
Old 05-18-2007, 03:49 PM   #7
Frizzle Fry
Frizzle Fry's Avatar
Shortening a frame and adding mounts is not hard either. I'd probably go that route.
Frizzle Fry is offline   Reply With Quote
Old 05-19-2007, 01:26 AM   #8
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
i agree, if you can get ahold of one that someone has already torn the body off of better yet.
milehightoyz is offline   Reply With Quote
Old 05-18-2007, 04:36 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Sell my 4wd for me then you can have my bagged 2wd frame pretty cheap
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-19-2007, 01:29 PM   #10
65-72 chevytoys
65-72 chevytoys's Avatar
Which is easier I would have to say the 4x4 blazer frame conversion is easier. But if you have the skills, tools, time, truck frame, then I say go for it.
THis might help also.
http://www.chuckschevytruckpages.com/framespecs.html
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 05-19-2007, 09:02 PM   #11
onetonk5
Cereal Killer
onetonk5's Avatar
If your looking to go low the I would suggest converting the 4x frame...with the area where the front crossmember goes in for 2wd being 1" higher on the 4x frame its like a 1" z without cutting anything.
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
