Old 05-16-2007, 11:26 PM   #1
mnky30
mnky30's Avatar
front suspension questions
i have a 1960 chevy pick up and i was wondering if the front cross member and a arms off of a 1882-83 pick up 3/4 ton would work and if i could convert the 3/4ton over if i changed the rotor and bearings to a 1/2 ton style.
please help?
vinnie
vinnie
1960 chevy c10 frame with a 1966 cab
2002 dodge intrepid r/t
2004 chevy 2500 4 door short bed
mnky30 is offline   Reply With Quote
Old 05-19-2007, 11:49 PM   #2
Slmd92DIME
Slmd92DIME's Avatar
Re: front suspention questions
Not sure buddy, I have a 65 and took 1/2 ton stuff from a 87 and put on mine. I am thinking that the control arms and crossmember would be fine then you would have to change the balljoints and get a 1/2 ton spindle which would hold the rotor and things. And you will have to make 4 holes bigger but it should be a bolt in other than that. Dont go by my word though man you might want to find info elsewhere. Dont you love how noone ever responds?
Slmd92DIME is offline   Reply With Quote
Old 05-20-2007, 11:37 PM   #3
mnky30
mnky30's Avatar
thanks i'll just get the x menber it is free so it cant hurt to try. yes i like the way no one comments back 1 out of 75
thks slmd92dime for comment
vinnie
Old 05-21-2007, 12:23 AM   #4
Captainfab
60-66 Nut
Re: front suspension questions
I've not done the cross member swap on a 60-62 myself.....I didn't think it would work because of the different frame. Then one day I saw one that was done and the guy said it was easy. Sounded like it was the same as doing it on a 63-66, just have to drill one new hole on each side, and elongate one each side. Yes you can convert that 3/4 ton to a 1/2 by changing the ball joints,spindles and rotors.....it's pretty straight forward.
When you get it done please post back and let us know how it went.
