Dave's not here, man
Disc Swap Progress Pics
For about the last week I've been in the process of swapping my truck to disc brakes. I had to park it temporarily due to gas prices, so I figured now would be a good time to tear it apart. Let me know what you all think, or if you see any potential problems.
This is the donor: an 89 'Burb. Not much fun pulling this stuff by myself. ![]() Took about 3 hours to get it apart and loaded in the truck. ![]() Disassembly ![]() ![]() Here's the parts cleaned and painted. I used Rustoluem and it seems like it will hold up well. ![]() ![]() Last one (for now) Took some time to get it to fit right with no clearance issues, but I think it's going to work pretty well. ![]()
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Re: Disc Swap Progress Pics
lookin good, amazing what a little paint can do
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Looks good, what all did you end up having to replace? It looks like you bought UBJ's at least. How much did the 'Burb set you back?
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
I just robbed the parts from it. A good friend of mine has his own "personal graveyard" for late model chevies. He charged me $50 for the front suspension, swaybar, booster, etc. So far I've replaced upper/lower ball joints, upper/lower control arm bushings and sway bar bushings. I still have to get tie rods, centerlink bushings, etc. and get the calipers and rotors, too. All the old stuff was pretty much shot. I was able to run brake lines today and get the booster linkaged hooked up. I still have some work to do, but it's coming along.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 05-19-2007 at 03:13 PM. |
Good deal, what you're doing is the epitome of hot rodding. Sure beats just installing mail order stuff (although new parts are fun sometimes too
They're showing up for me now; not sure why they won't for you??
Active Member
![]() Join Date: Jun 2002
Looking good!
Did you have any problems getting the booster to pedal connected? I have an 81 GMC I am getting parts from and would like to use the booster and MC from it, going on 3 yrs now ![]()
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
Some of the guys on here used a coupler and threaded rod to lengthen the linkage, but I did mine a little differently. I attached the new linkage directly to the pedal using the same shouldered bolt that came factory. I just had to grind down the shoulder so it would fit through the new linkage's opening. My pedal sits a tad lower than it did factory, but I still have enough room between the pedal and toepan with the pedal fully depressed. I hope I'm making sense in how I'm explaining this.
Here's a link for Brad's setup with the coupler and rod: http://67-72chevytrucks.com/vboard/s...d.php?t=215980 Here are a couple pics of mine installed. I haven't driven my truck yet so I don't know if I'll have any problems or not. ![]() ![]()
I am a Referee of life.
Uhhhhhh,89 "burb?If I remember correctly there is a track width difference that started in '86.Better check with the guru's of the swap.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Everything seemed normal when I test fit the upper and lower arms and the crossmembers are nearly identical. I thought 88-91 Burbs were the same as 73-87. I posted awhile back regarding that very thing but didn't get much of a response. Guess I'll find out soon enough.
Active Member
Thanks for the info. This gives me the inspirations to finish and get one more vehicle out of the yard to make the wife happy.
i dont think the track width is different, but i could be wrong
I don't think so either. Both crossmembers are same width a-arm to a-arm so I think I'll be o.k.
