05-21-2007, 11:11 AM | #1 |
oil pressure ?
ok i got a 350 when i start it up i have about 50 some time 60 psi in oil pressure and then i drive about 2 or 3 miles and i start lossin oil pressure it go down to a bout 10 or 15 psi. it get to where when i come to a stop light i have to put it in N so i have some oil pressure if not it will go to 0 if i have my foot om the brake.
ridin big yo 5in cpp lowerin springs in back lowered 3in in front with cut springs for now 5 lug swap and disk in front 5 lug and disk in the rear with 3.23 gears mild 350/400heads 7547weiand intake 600 Edelbrock chrome block hugger headers 2 1/2 pipes in to a x pipes super 40 flows and turn downs turbo 350 with shift kit Last edited by 65 on 24's; 05-21-2007 at 11:12 AM. |
05-21-2007, 11:28 AM | #2 |
Re: oil pressure ?
Is your oil pressure guage accurate? I would hook up a mechanical test guage and go for a ride to verify if your engine actually has low oil pressure or if you have a bad guage or sender.
05-23-2007, 10:19 AM | #3 |
Re: oil pressure ?
yes it is i have had 3 diffrent oil pressure guages on it i have had a few peeps tell me that i need new mains or my crank needs to be turned
ridin big yo 5in cpp lowerin springs in back lowered 3in in front with cut springs for now 5 lug swap and disk in front 5 lug and disk in the rear with 3.23 gears mild 350/400heads 7547weiand intake 600 Edelbrock chrome block hugger headers 2 1/2 pipes in to a x pipes super 40 flows and turn downs turbo 350 with shift kit |
05-23-2007, 11:50 AM | #4 |
Re: oil pressure ?
what oil are you running.. YOu might have to go to a straight weight oil now or get the oil formulated for engines over 75,000 miles.. It might work you never know...
