05-22-2007, 12:26 AM | #1 |
Kung Fu Master
Wrong fuel pump? Lower pressures?
I came to the conclusion I needed a new fuel pump. Went to parts store and was given a new pump. It looked the same, but when I fired it up, it seemed pretty obvious it was not pumping enough gas. Ran very poor, and had no power at all. It wouldn't even keep my clear filter half full. Anyway, I do some looking and they make a pump for a MT and an Auto. IF I got the one for the MT, would that make a difference if I have the Auto? Higher fuel pressure? I wouldn't have thought it would make a difference. Anybody have any ideas? It's a 72 with a 350 A/T. Will see about taking it back tomorrow.......if they let me.
72 GMC SuperCustom 4x4 1972 Chevrolet Cheyenne Super 4x4 |
05-22-2007, 12:49 AM | #2 |
Re: Wrong fuel pump? Lower pressures?
Sounds more like you just got a bad pump off the shelf or your filter is plugged.
While you're checking the filter, it would be a good time to check your oil for fuel contamination in case the new pump has a bad diaphragm. Oil doesn't lubricate as well once it's been diluted with gasoline. |
05-22-2007, 05:50 AM | #3 |
its all about the +6 inches
check the fuel line from the tank to the pump, and even pull the sending unit outta the tank and see if the stupid sock is clogged.
05-22-2007, 11:33 AM | #4 |
Kung Fu Master
I'll check out a couple things tonight and post my findings......if I have any.
