A/C in 64 Burb??
Hey guyz, I've been lurking around here for a while now and thought I'd finally post a question.. I just picked up a 1964 Suburban/ Carryall. It has factory A/C. the compressor, condensor, and anything else bolted to the engine or front clip is missing.. My question is.. How well did the factory A/C work??? Is it worth restoring and using?? The project is going to be a full custom Burb with airbags, overdrive trans and 348 W motor, so originality isn't and issue. I just figured if I had it, I might as well use it (if it's worth it).
you guys give great advice, and do some awesome work to by the way. I hope I can measure up!! Thanks for any help!! ![]() |
It Is What It Is
Re: A/C in 64 Burb??
JWI, I'm running the factory air conditioning in my '65. It works great. The setup is alot like the aftermarket units in that it works on the inside temp and not a pressure switch. IMO it would be worth using if you have everything from the firewall and inside. I used '71-'72 Chevy truck A/C brackets on mine, bought a condenser setup aftermarket, and the compressor manifold from Kenny's. Had the A/C lines made up locally. American Classic has a good bit of stuff for the inside unit (cables,switches,relays, etc.) Do a little bit of research and see if getting all the things you need to make the factory A/C work outweighs the cost of an aftermarket unit. I just like the way the factory A/C looks. Good luck, and post some pictures of the Burb! Kevin
Hollister, CA.
![]() Join Date: Sep 2006
65SC hit it right on the nose. I would recondition and run all the firewall-in A/C stuff, and run all new upgraded stuff on the engine side.
Fab up some custom mounts for that W motor...that thing will be super-trick !!! Good Luck !!! Keep us posted !!! John
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
Thanks for the suggestions guys. Hopefully I'll get started soon.
call me dumb but whats this 348 W motor exactly?
id love to see pics of it to
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
I have a 65 with factory air and it works excellent. I would recommend using Old Air Products (www.oldairproducts.com)
They supply places like LMC, Classic Industries etc. Their staff is knowledgeable and they ship immediately. I think they have an on line catalog I hope this helps. Cheer Paul S |
