05-24-2007, 10:51 AM | #1 |
CAN'T FIX NOTHIN
the 36 grit bed (PICS) PAINT !
here is the bed I started on a couple week's ago and that some freaked out on me cause I sanded it with 36 grit snading disc (WHICH IS NORMAL TO ME)
and for the record you CAN fix the aftermarket taligate to look good and align perfectly ! it just takes some kicking and screaming cursing but it can be done !! sanding old paint off with 80 grit is like taking a knife to a gun fight !
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
05-24-2007, 10:53 AM | #2 |
Re: the 36 grit bed (PICS) PAINT !
sweet
i wanna see that thing outside
69 4wd V6 20k orig miles!! 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
05-24-2007, 11:04 AM | #3 |
nice work looks good
1972 C10 1972 C20 |
05-24-2007, 02:51 PM | #4 |
CAN'T FIX NOTHIN
05-24-2007, 02:53 PM | #5 |
CAN'T FIX NOTHIN
I want to see it up at the cruz in sat night !!
05-24-2007, 10:59 AM | #6 |
Man that's nice work! What's your address? I'm sending you my aftermarket tailgate...
Pete |
05-24-2007, 11:15 AM | #7 |
Cowboy Fan for Life!!!!!!
What was your progression of sandpaper? 36 grit - 80 - 220 - 320? I take it lots of priming and blocking maybe? Some paints are harder than others to remove. I'll usually try some paint stripper first before going down to 36 grit. I'm just always scared I'll end up with lots of little sand scratches once the paint really cures good. Your's looks real nice, can't wait to see it assembled........................Bamm!
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
05-24-2007, 11:16 AM | #8 |
Nice Job! letters look great too.
05-24-2007, 03:11 PM | #9 |
I was just referring to that if you started with a smoother base you will have a better end result. Less work in the process as well trying to fill 36 grit sand scratches. What do you finish your body filler in?
05-24-2007, 04:28 PM | #10 | |
CAN'T FIX NOTHIN
you are going to block your primer ANYWAY to obtain a straight body , so in doing that you will take care of any scratch's without even trying , even new panel's such as door fender's hood's or whatever need to be primed and blocked , I start with 36 on a 6'' disc with a drill cut it all down get rid of ALL old paint surface rust and such , then I use the bondo to take care of dent wave's or whatever you need , then sand the bondo with 36 grit on an straight line air sander , prime it then sand with 180 prime it again go up to 220 till you get it pretty straight then prime it again and finish with 320 , paint it ! and even with all that on a color like black you can still see little wave's and such if you look at it down the side on the right angle , that dosen't bother me because you can go look at a new truck and do the same thing ,
05-24-2007, 03:41 PM | #11 |
its all about the +6 inches
THAT looks killer.
05-24-2007, 03:45 PM | #12 |
Active Member
I can't wait to see this truck finished. (although probably not as anxious as 19673ontree)! I love the contrast between the black paint, and the white trim. It's going to be one sweet looking truck!!
05-24-2007, 04:01 PM | #13 |
Man that tailgate looks good,you must be a better cusser than me to get it to fit like that.
Great minds think alike,So do ours |
05-24-2007, 05:13 PM | #14 |
Please...no more teaser pics until the beds on the truck, I can't handle it.:happy:
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
05-24-2007, 05:29 PM | #15 |
Gone Fishing
That looks killer
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
05-24-2007, 06:16 PM | #16 |
The LuvShack Garage
05-24-2007, 07:17 PM | #17 |
CAN'T FIX NOTHIN
here is some pics of the truck as I am putting it together , I took today off to work on the truck so I can go to the car cruz sat night with it , well back out and put the rear wire harness tailight's and bumper on !!!!!!!!!!!!!
oh yea painted the hubcap's today too !! I bet I'll have the slickest hubcap's of anyone at the cruz (ONLY ONE'S TOO)
05-24-2007, 09:14 PM | #18 |
Aluminum slot wheels rule...
Wanna paint my truck? That looks sweet.
05-24-2007, 09:28 PM | #19 |
Well done, it looks really good!
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
05-24-2007, 09:43 PM | #20 |
Where's the cruz at?
05-24-2007, 09:53 PM | #21 |
Quenton Lee Midlothian Electric Comapny Inc. Electrical Contractors Since 1965 |
05-24-2007, 10:30 PM | #22 |
CAN'T FIX NOTHIN
they are two cruz's that I go to , one is here in my hometown of grundy on sat night sometimes as many as 40 old car's and truck's , the other is in elizabethton tenn it's about a 2 hour drive and has upward's of 150 old car's and truck's ,,,,,,,,,,,
I got the tailight harness tailight's and bumper on but it's too dark for pic's , tommorow evening I'll get to work on it some more , you know I have done this complete job by myself in just shy of 3 month's !!! I AM TIRED !!!!!
05-24-2007, 11:10 PM | #23 |
Great job! Cant wait to see pics of it completed.
05-25-2007, 01:38 AM | #24 |
The Original HotRod KnifeMaker
One thing I have learned is that there are always a dozen ways to do something right. We pick up work habits through trial and error that work for 'US' the best.
Early on in my knifemaking I had several other makers tell me to start with 36 grit belts. Ruined the first four knives, haven't put a 36 grit on any of my grinders since then. Everyone has things that they do a certain way that works for them. Your finished paint is much nearer perfect than I could do with 5 years of block sanding. Love the truck, love the paint, love the fact that you have found a method that works for you so well. Please do post more pics as you get it finished up- I love the 'Tuxedo' black paint with only enough white/chrome to make the black even blacker. Just a gorgeous truck, you should be proud of your work. Thanks for posting the pics!
Dave 69 GMC SWB 2WD 454 Turbo 400 |
05-25-2007, 03:48 AM | #25 |
that is deffinitly one of if not my all time favorite truck on here, i just love how sweet and simple it looks but yet so badass at the same time, the simple trucks are my favorite ones and your truck just defines that, cant wait to see the rest of it together, what are you doing with the interior and engine bay?
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
