Old 05-27-2007, 07:39 PM   #1
68 Stepside
huh?
68 Stepside's Avatar
Drop spindle installation problem! Help!
Hey all,
Several years ago I ordered a 2 1/2" drop spindle/disc brake conversion kit from GMC Paul. I finally got around to putting it on, and after checking my ball joints which, to my surprise, are in great shape, I decided to reuse them for the time being. I got everything seperated, put on the new drop spindle, bolted it all up tight, and now can't turn the spindle without an act of congress. The top mounting point of the drop spindle is squared off, and it's catching on the top a-arm. Is this a problem that's common? This is a McGaughy's Classic Drop kit, I would guess the part number is 6370DS. When I ordered the kit, I made sure it was the kit that used the stock front end parts (ball joints, tie rods).
It's rubbing where my finger is in one picture, right at the front, on the bottom lip of the upper a-arm. It's really a difficult problem to describe, I'll include a few pictures to try and clear it up. I hope it makes sense, I was hoping to have this thing back on the ground by tomorrow evening.
I would appreciate any information that I can get. I'd just call GMC Paul, but I work 4:30am-6:00pm.
Thanks in advance for anything.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 05-27-2007, 08:14 PM   #2
SCOTI
SCOTI's Avatar
Re: Drop spindle installation problem! Help!
Sounds like the upper BJ 'shaft' isn't the correct length for the spindle.
I would call & dbl check the part #'s to make sure they sent you the correct stuff to work w/your stock BJ's. You could also compare the shaft length on the BJ's included in the kit vs. the ones currently installed.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-27-2007, 08:20 PM   #3
royo
royo's Avatar
I cant see it good can you grind some of the metal off to make some more clearance
nickle and dime
royo is offline   Reply With Quote
Old 05-28-2007, 09:30 AM   #4
royo
royo's Avatar
on the lip of the a frame grind some of it
nickle and dime
Old 05-27-2007, 10:12 PM   #5
Shane
Shane's Avatar
maybe it's just my piss-poor eyes, but something looks weird with the end of that upper control arm ... it looks real short (from the radius on the end to the balljoint).
Shane is offline   Reply With Quote
Old 05-27-2007, 11:26 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Although it's hard to tell with the cat fur in the way, I think your right. That still wouldn't have an affect on the ball joints though.
Somethings wrong for sure.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-28-2007, 02:10 AM   #7
SCOTI
SCOTI's Avatar
If the taper in the spindle does not match the BJ, the BJ could sit closer to the a-arm. Since he's using the factory BJ's, that would be the first item I would consider.
Compare the BJ shafts/tapers & see if there's a difference.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-28-2007, 09:46 AM   #8
Billla
Billla's Avatar
I agree - it looks like the end has been bent over. There should be a flat lip there...?
Billla is offline   Reply With Quote
Old 05-28-2007, 05:30 PM   #9
70c10
67-72 Addict!
70c10's Avatar
68stepside- I just went thru this problem with the same kit. Look at the top of your spindle. The raised pad is squared! Your upper control arm has a rounded radius. You have to trim a little arc on the corners of the pad to match the turning radius to clear it. It takes a few seconds to do each spindle. I think McGaugheys should have fixed this but they didn't. Look at this pic of an Early Classics spindle and notice the there is no pad at the top! Hope this helps
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-28-2007, 07:12 AM   #10
68 Stepside
huh?
I wasn't very clear in my original post. The kit did not come with ball joints, I am supposed to be able to use all my stock front end components. The parts stores did not have upper ball joints in stock, so I didn't get any yesterday. Should I get a new set, install them, and see if that makes a difference? This kit is a good 4 1/2 years old now, and has just been sitting. The original box is long gone, lost it when the basement flooded some time ago. Getting the part numbers could prove to be a challenge.
I should have just swapped the entire front end out with one from a later model, this truck has fought me from day one, exactly 7 years ago now.
RIP El Jay
Old 05-28-2007, 07:33 AM   #11
68 Stepside
huh?
Well, I did some investigating, and GMC Paul still carries the spindles that I have. Classic Drop PN 6072R/L.
1963-70 2 1/2" drop spindles, these use all your original equipment ball joints, tie rod ends, etc.. These spindles are Made In The USA on State of The Art CNC machines. All spindle pins are made of 4140 Chromoly steel and machined on CNC turning machines for the ultimate in precision tooling. These require the use of our disc brake kits and will not work with drum brakes. Lifetime Warranty.
Now I really don't get it. Could my upper ball joint be so screwed up that it's causing the problem? I was going to replace the uppers anyway, but as I stated before, they're on order.
RIP El Jay
Old 05-28-2007, 10:14 AM   #12
68 Stepside
huh?
I guess I should pull the other wheel and check out the other a-arm huh? I thought about grinding it, but wasn't sure. I'm a newbie when it comes to suspension, I'll go have a look and see what I can figure out. Thanks for all your replies.
RIP El Jay
Old 05-28-2007, 10:24 AM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
You shouldn't have to grind anything to make them work. Like Scoti said you either have a different BJ on there with a smaller taper or the BJ is worn out.
Articles-
"Refining Sierra"
Old 05-28-2007, 11:28 AM   #14
royo
royo's Avatar
yea you shouldnt have to grind but you might have too also how about knocking some of that crud off there while your at it
nickle and dime
Old 05-28-2007, 11:34 AM   #15
royo
royo's Avatar
heres a pic of what it looks like hope it helps it truely was r-r this is sitting on the ground
nickle and dime
Old 05-28-2007, 02:41 PM   #16
bkg1986
hey maybe i can help i just put the same spindles on my truck about ten mins ago i had same problem but you probably don't have your top control arm bump stop in correct?....which is part of it and i you will notice if you stick jack under the lower control arm and jack up it lifts off spot were its rubbing.....so when you get wheel back on it and let it down it will raise it off of it....try that cause i put new ball joints on also i'm going try that before i star cutting stuff....
bkg1986 is offline   Reply With Quote
Old 05-28-2007, 03:33 PM   #17
68 Stepside
huh?
I'm sure it's the ball joints being worn. I'm going to replace them anyway, they're just on back order, thought I'd throw it together anyway. I got the drivers side on, but the passenger side is seized to the lower ball joint. Should be fun to seperate considering I have basic tools....
Actually yes, I do have the bump stop in, scared me when I noticed the upper control arm moving upwards while I was loosening the nut.
RIP El Jay
Old 05-28-2007, 10:00 PM   #18
jjk3
It's just a check engine lamp.
jjk3's Avatar
I had the exact same problem with my McGaughy's spindles (should be the exact same set). I also installed new balljoints at the same time, so that's not the problem. Like 70c10 said, it seems to be a machining error. I painted mine before I installed them, so my only option is to grind a little on the spindle.
Also, like bkg1986 said, the problem is worse when the suspension is unloaded. Good luck. John
Active Inliner---bigchevy66
68 SWB Stepside 250 L6/3 on the floor/ Hedman headers, HEI, MSD 6A box, K&N filter, Offy intake and Edelbrock 600cfm 4 barrel
Soon to have: WC T-5 five speed
66 SWB Stepside-undergoing restoration
jjk3 is offline   Reply With Quote
Old 05-28-2007, 11:28 PM   #19
gringoloco
A guy with a truck
gringoloco's Avatar
Just ran into this on a buddy's '66 using McGaughy's and brand new balljoints.
I agree with everyone above. Once you set the weight of the truck down, it's not a problem. Only thing we were worried about was if the front suspension unloaded while driving, you may run into a steering lock issue. Not good.
Either grind the spindle a little and take the corners off of the 'pad' or buzz a 1/4" or so from the control arm lip.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-03-2007, 01:11 AM   #20
Inverter
Inverter's Avatar
+1,,,Buzz the lip on the arms.
Inverter is offline   Reply With Quote
Old 06-03-2007, 03:27 AM   #21
SCOTI
SCOTI's Avatar
If the McGaughy's spindles have this issue..... I would 'round-out' the corners of that 'pad' (after consulting w/one of their reps) before I would grind the lip of my a-arm.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-03-2007, 11:11 AM   #22
70c10
67-72 Addict!
70c10's Avatar
. No need to grind anything but the new spindle pad corners. If you spray paint the spindles and rotate them by hand on the truck it will scribe the arc you need to trim
Jim
Old 06-15-2007, 01:07 AM   #23
lowdowndirtyshame67
Undo the upper ball joint and move spindle out of the way. Take a crescent wrench and tighten it on the lip of the control arm and bend the control arm upward slightly. You will prob have to do it little by little, working your way around the outer edge. Then remove some material from the spindle where there are clearance issues...Worn ball joints would actually pull the spindle away from the upper control arm because of how the spring loads it! But O'Rielly's has the upper ball joints in stock for $16.99, so why not replace them while your down there...
lowdowndirtyshame67 is offline   Reply With Quote
