Old 05-30-2007, 06:19 AM   #1
texanidiot25
Eat My Rust
texanidiot25's Avatar
Converting an auto trans truck to stick?
After having a weekend mudding in an old TOY, and it being stick, Ive fallin for the charm of slamming through the gears.
And since my truck has no transmission (originally a Turbo 350), I was wondering the mods needed to the cab and steering column to make it 4 on the floor friendly, if I were to go that way.
I cant find the thread anymore where I saw this, and the search is being useless to me tonight, or maybe its just too early for my brain, either way...
Anybody tried this?
texanidiot25 is offline   Reply With Quote
Old 05-30-2007, 06:25 AM   #2
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Converting an auto trans truck to stick?
as far as the floor its just cutting a hole but its a pita to get the clutch setup right unless you get it from a 67-72 truck and you can just get a colum from a manual truck
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-30-2007, 06:29 AM   #3
texanidiot25
Eat My Rust
Ill go dig up my classic-trucks-parts mag, I think they have clutch parts in there. Didnt think about that.
Too bad the local junk yards are always dry on our trucks, never seen one around.
Old 05-30-2007, 06:30 AM   #4
GREASEMONKEY72
im afraid to look at the yards around here till i have money
-steven
Alte Seele S.S.
Old 05-30-2007, 06:35 AM   #5
texanidiot25
Eat My Rust
Helps if you go with a friend or family member that has a clear head.
Old 05-30-2007, 06:36 AM   #6
69rut
XIV. As of October 15th 2005 subscribing members will be the only ones permitted to post for sale and want to buy ads on any classified section of this site. All other rules of buying and selling still apply. 67-72chevytrucks.com, its administrators or staff are not responsible for any transactions on or off the forums. We will work hard to ensure you a smooth transaction, and help in the event you may need it, but all for sale and trade areas are buyer beware. Any persons who have misrepresented an item, lie about an item, fail to deliver, or are in violation of any of the rules will forfeit there subscription fees and be banned from 67-72chevytrucks.com
Please subscribe and post for sale ads in the parts board
trailers are for boats
Last edited by centsless; 05-30-2007 at 01:20 PM. Reason: for sale in wrong area by non subscriber
69rut is offline   Reply With Quote
Old 05-30-2007, 09:26 AM   #7
cdowns
cdowns's Avatar
you'll need a manual tranny crossmember// too bad you arent closer cause i have one on the scrap pile
Old 05-30-2007, 10:06 AM   #8
rambler
MOVE OVER
rambler's Avatar
same here,, I have a 72 with a 4 speed granny low, all complete thats my parts truck,
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 05-30-2007, 11:12 AM   #9
dubs68SWB
dubs68SWB's Avatar
You actually don't need a manual tranny crossmember. The crossmember used for the granny 4 speeds are mounted quite a bit forward and wont work farther back. I used a crossmember out of a 3/4 ton with a TH400 on my M-22 and it worked perfect. I just had to get it centered and drill some holes. You will definately have a driveline issue though. I was able to take my beefy one piece with a slip yoke and have it cut down to have the yoke attached to the driveline like a car is. It's now bullet proof and you can see by its size.
dubs68SWB is offline   Reply With Quote
Old 05-30-2007, 09:58 AM   #10
truckdude239
truckdude239's Avatar
Originally Posted by 69rut View Post
I am going the oppsite way you are.
Have a three on the tree column, pedals, and "Z" bar pivot that mounts in the frame. The truck was a six/three speed and I no longer have the shifter arms and clutch pieces from the tranny.
Send PM
please keep parts out of the forums unless you are a site supporters or it will be locked ty gl with the switch
subscribe here--> http://67-72chevytrucks.com/vboard/payments.php its the best 25 buxs i have ever spent
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-30-2007, 10:09 AM   #11
dubs68SWB
dubs68SWB's Avatar
I just did the exact same thing you are thinking about doing. I went from a 250 inline and the granny tranny to a 460 BBC with a Muncie M-22. There will be some mods, but not too many. The only real issue will be the bellcrank. Actually, for you, it might be a bit harder because you are now an auto (I just realized that you don't have a clutch pedal. Since most of these old trucks had that granny low 4 speed, all you need to do is take all the parts off of one in a wrecking yard and put it on yours. It's actually easier than you may think. The bell crank will still be the hardest part. You will probably have to do what I did, which is cut and relocate one of the z bar arms because the angle for the old setup wont be right. What sucks is that it's hardened steel. You will need a pretty hot welder. If you have a high hump, linkage won't be an issue....it will clear with no problem. Let me know if you are really serious and I can get you some more info.
Old 05-30-2007, 11:08 AM   #12
69rut
[QUOTE=truckdude239;2198716]please keep parts out of the forums unless you are a site supporters or it will be locked ty gl with the switch
Just trying to help
Old 05-30-2007, 01:04 PM   #13
truckdude239
[QUOTE=69rut;2198767
Just trying to help[/QUOTE]
i know just dont want to see anyone get in trouble
David fuller
2000 Tahoe 5.3l 378
Old 05-30-2007, 01:23 PM   #14
centsless
sufficiently talented fool
centsless's Avatar
Nobody's in trouble, but if I let one go, then I have to let em all go, and you know what happens then......lol
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 05-30-2007, 11:08 AM   #15
67ChevyRedneck
67ChevyRedneck's Avatar
It's a pain in the ass to get the crossmember out of another truck... they're full of rivets and aren't easy to get to, unless the motor and tranny are out. I caught my truck on fire torching them out
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 05-30-2007, 11:16 AM   #16
67ChevyRedneck
Do the 4 speeds use the "up front" crossmember (bolts to belhousing).... or one in the back (under the tailshaft) like an automatic?
3 speeds and granny 4 speeds use the belhousing crossmember, correct? So a car style 4 speed would need a tailshaft crossmember?
Jesse James
Project "On a Dime"
Old 05-30-2007, 11:19 AM   #17
1969k10stepside
If you are going to use the granny first gear SM465 you will need to put in a "high hump" floor.To do that...you will need to cut a hole in the floor and drill holes for the bolts that hold down the hump.Then you just have to buy the floor hump.Thats the mod to the cab you will have to do
1969k10stepside is offline   Reply With Quote
Old 05-30-2007, 11:38 AM   #18
71chevylowrider
71chevylowrider's Avatar
I found a very good deal on a manual transmission column for you.
http://portland.craigslist.org/clc/pts/339779786.html
71chevylowrider is offline   Reply With Quote
Old 05-30-2007, 12:41 PM   #19
dubs68SWB
dubs68SWB's Avatar
My Gosh.....why would you want a "3 on the tree"????? Put the linkage on the floor. You will need to do some fab work on the shifter arm because, if you have a bench seat like I do, it's a long ways from the shifter to the top of your seat.
To answer another question......The granny 4 speeds are very short which is why the crossmember is almost under the firewall. You will have to use the style that goes under the tailshaft. You are not limited to a truck x-member though. Before I used the GMC one I had, I threw a '68 Camaro x-member under there and it would have worked with no mods. The only thing is that you may have needed to shim it a bit to get the angle you were looking for.
If you are thinking about any kind of a close ratio 4 speed like a Munice 21 or 22, stay off the column shift cuz you will look funny going down the road trying to shift fast enough....people might think you are having a medical event!!!!! LOL
Old 05-30-2007, 12:50 PM   #20
72 cheyenne pdx
72 cheyenne pdx's Avatar
Another option you might want to do is keep it as an automatic and put a floor shifter kit on it.
72 cheyenne pdx is offline   Reply With Quote
Old 05-30-2007, 10:38 PM   #21
sodak69c10
sodak69c10's Avatar
on the crossmember note, i run a muncie car tranny off the belhousing X-member what other model crossmembers would work for this, i going to have to notch it for my exhuast so i just wondering
,Clint
LOUD PIPES SAVE LIVES
69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA
sodak69c10 is offline   Reply With Quote
Old 05-30-2007, 11:06 PM   #22
texanidiot25
Eat My Rust
So the current trans crossmember wont fit up?
Im just planning this btw, no were near buying parts. Close to having enough for a motor though, sbc 350
Im not goin for a short ratio 4 speed, Its gonna be my DD to work and school, all of which is highway driving pretty much. And no 3 on the tree for me.
What was the manual trans for the trucks, the 400?
Old 05-30-2007, 11:22 PM   #23
1969k10stepside
The stock manual tranny was the Granny 1st gear SM465
Old 05-31-2007, 06:18 AM   #24
69rut
Seems to me that a auto crossmember would work as the position is the same for car manuals at least.
Is ther a difference between car and truck transmissions?
I plan to use a crossmember from a V-8 auto. Once the motor/tranny is in, I will square it up and bolt it in.
Old 05-31-2007, 10:25 AM   #25
dubs68SWB
dubs68SWB's Avatar
An M-20 would be a good trans for you because it's not a close ratio and they are pretty cheap. I recently sold one with the flywheel, pressure plate, clutch, shifter and trans for $600. They run a lot less than the M-21 or 22's. It's also nice because they have a lower 1st gear ratio which helps get those heavy rigs moving.
To answer your other question....a 400 is a turbo hydro 400 which is GM's toughest auto in those years.
