Blank
rear axle shims? correct pinion angle?
So I'm going down to a 7" drop in the rear. I bought 3deg shims to correct the angle for less vibration. Anyone know which way they go in? pinion has to go down or up? Thanks
![]() 1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi. 1977 Corvette 350-375hp 4speed, silver show car. 2002 S10 xtreme, work truck 2004.5 VW jetta GLI 1.8T 6speed, weekend warrior. 2013 Audi A3 TDI, the wife's car |
Re: rear axle shims? correct pinion angle?
if you are lowering the truck the wider end of the shim would go tward the front if you are raising the truck it goes to the back
No NO NO Sir Don't Want em Can't Use em Couldn't Afford em If I Did |
