Paint Job Prices
I am thinking of getting my '69 C10 painted. Never had one done before, and it looks more work intensive with the interior and all needing painted than a normal vehicle. What type of cost am I looking at?
Re: Paint Job Prices
Anywhere from $3,000.00 to a blank check. It all depends on what you want..show quality or driver. I always would like to see other customers cars before they touch mine.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
Mine was $5,500 There's a board member on here with a gorgous black truck that cost $19,500 to paint, I agree, you need to see the work they are putting out before you leave your vehicle with them, I've seen too many friends go witht the cheapest place & it sits there for months & when he finally hounds them enough to get on it, they whip it out in no time & it looks like crap.
I had my truck painted in 1994 for $3000 plus materials. Total for the job was about $4500 (Red paint is expensive!). At the time the painter was doing jobs on the side. He showed me pictures of other cars, and trucks he had painted. He also took me to go look at a truck he had recently finished.
He's now painting full time, and the same job would probably cost me about $7-8K. Although I think now I would do the majority of the disassembly/prep work, and mainly leave him with only minor prep work and spray... I'll probably be doing just that within the next year or so. It's been about 13 years since he painted my truck, and there are some areas where the clear coat is lifting. I also need to replace rocker panels..... If there's anyone in the SF bay area interested in having him do some work for you, you can get his contact info at: http://www.reflectionautofinishing.com/ He's also done some repair work on my truck since it's been painted, and he's done a great job.
Rudy Fierros '95 Honda VFR750F Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it! |
CAN'T FIX NOTHIN
I just painted my truck and it took almost $1000 buck's in material alone , I used all my own tool's (SAD AS THEY ARE) and did all of it myself , I have no idea what you would have to pay for good quality work ,
I wish I had somewhere to spray the paint without all the bug's and dust all over the place , have you thought about just painting it yourself ? here's mine ,,,,,,,,,,,, paint came from NAPA I actually like PPG better but NAPA let me have a charge account SO NAPA IT IS ![]()
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
WTB this ad
I spent right at 10K on my 4x4 right at 9 1/2 years ago. That does include a large amount of rust repair as well. A painter that I have been using recently quoted me 7-8K to do my C10.
#7 | |
Cowboy Fan for Life!!!!!!
I hope my truck throws off a reflection like that when I'm done........... Nice..............................Bamm!
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
Also depends on how much work you do. If you take everything apart and prep everything, you can have it shot for around $800 + paint.
I have seen people spend $5k and not be happy because they skimped on the prep then over paid for the paint.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
Junior Member
holy sticker shock batman! so uh... no maaco then??
i have a dream of pulling it all apart and doing it all myself someday... might be even closer to reality if its going to 5 grand to paint it again! of course, the opportune time would be at the point of the full-frame-off when its time to start putting it all together. Last edited by RedZ71; 05-30-2007 at 04:24 PM. |
I just got mine back and it cost me about $4,000. But that was bringing the truck completely disassembled and sandblasted and given back to me disassembled! I priced having it done with bringing him the complete truck and he doing the sanding and disassembling and it was in the $9000 range. Just depends on how much elbow grease you apply..
-Scott- 1970 C10 shortbed 396 1969 C30 dually flatbed "Vidalia" |
#11 | |
BlahBlahBlah
Same way I'm doing my panel...no way I could afford it otherwise. |
Sierra Grande Club
Good set of rims w/ a nice stance, these trucks will look good! Even with spots of primer, and mixed panels!
I say don’t rush it…save up until you can get exactly what you want. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Junior Member
In so-cal your looking at $3-4,000 for body work and paint! That's a driver quality paint job inside & out! I will repaint my 71 GMC in the next year or two!
Junior Member
no need its sweet.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
#15 |
I just finished shooting one and it was over 4k in just material
![]() Kevin LFD Inc. |
#16 |
i say just take your time and paint it yourself, its not hard, all you need is some tarps and a canopy
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
#17 |
LAIDOUT
I have done everything on my resto project myself, working on build primer and blocking now. If I go back 2 1/2 years and just add up the materials, tools, primer and paint products I would say I am at about $2,500 or so. When I am done I will have painted every surface of the truck. Fixing just the exterior and not taking it down to the frame would be cheaper obviously. I bought a little pressurized sandblaster, several cheap then one pro paint gun, gallons and gallons of primer, paint, and chemicals, sanders, many sanding blocks, etc. I have probably spent $300 just on sand paper. I can't go to the auto body store without dropping two bills its seems like...
I started knowing next to nothing about auto body and paint at the beginning, but my skills are improving. Its a real fun learning process. It helps a bunch that my wife is ok with living at a body shop [the mess, the fumes] and parking her car outside in the snow, so I feel lucky about that. The best part is yet to come though when I roll the truck out of the garage done, all my friends that think I was nuts to take apart a functioning truck will be so surprised ![]() |
#18 |
![]() Join Date: Feb 2001
Some of these guys make it sound easy. It's not. Spraying is easy. Getting the body work done and straight is the hard part. If you have never done it you will have a lot of learning to do. There are tools and supplies you will need and knowing what works with what. I'm just gonna let Calvin take care of my baby. Guys like Calvin are very hard to find!!!!!!!
#19 |
Thanks for all the replys guys. It looks like its gonna cost more than I thought, but thats why I asked. I figured $2000 tops. Looks like I need to keep saving pennies!
#20 |
A buddy of mine paid $1,000.00 per gallon for his PAINT! I could never see doing so unless it was a super rare car. As said before, in my past experience I say getting it ready to paint is the worst part, a few good air tools and you can tear the truck down in no time. Remove the glass, rubber etc. You will be much happier in the end.
#21 |
Licensed to Thrill!
Mine was $7,000 about 8 years ago.
Minor body work. Rust in the floor, and had a new bed plate welded in. Did have a few mods done to it. The prep work was extensive though, and it was taken apart and put back together. It's painted inside and out. DLB |
#22 |
Active Member
![]() Join Date: Dec 2002
Location: West TN (Memphis area) now. East TN (my favorite place to live).
What the old saying? If you have to ask, you can not afford it. I had my motor out and parts lined up for the painter. I knew him when he first started painting. He had painted several of my friends cars 68, 69 camaros, and novas. He does excellent work.
Something told me to talk to him before he started. I am glad I did, because he could not give me a price. He told me it could be from $3500 to $8500 for the paint and body work. If he would have told me $4000.00, I would have my truck in the shop now. That price range scared me off. But from what I have been told, he has started to scare a lot of people off. Here is one of the cars that he painted. http://dubmagazine.com/dubshow/07Mem...s/IMG_9612.htm http://dubmagazine.com/dubshow/07Mem...s/IMG_9613.htm http://dubmagazine.com/dubshow/07Mem...s/IMG_9613.htm If anyone in West Tenn wants his number, send me a PM. He works on 1 car. If I did not have to pay for my wife to go to college, and 3 kids that eat, I would have him paint my car.
BigFredTN 70 chevy stepside 350 with some goodies inside, turbo 400. 69 Chevy long wheel base. Dad bought new in 1970 62 Chevy Impala 98 GMC Yukon 1970 Ford Mustang Fastback I know its a Ford. |
#23 |
CAN'T FIX NOTHIN
forgot this ,,,,,,,,
this is true !!!!!!! the hard part of ANY paint job is getting the money to buy the material !!! after that it's a cake walk.
#24 |
Always Fixing Things
Here are some details on my paint.
Filler: 3 gallons of Lightweight filler, 2 gallons are probably sitting in my shopvac (I suck at Bondo) ($18/gal) Primer: ¾ gallon of Epoxy primer/sealer ($75) 2 gallons of high-build polyester surfacer (should have used other 2) ($120) Spot etching primer on all my sand-throughs Sealer ¾ gallon Standox sealer ($100) Color: Light Quasar Blue (’93-’95 GMC) Standox Base – He mixed 1 gallon, sprayed over 3 quarts of it ($320) (enough left over to do the bed) Standox Clear – about 3 quarts, 3 coats on the hood and roof, 2 coats on sides ($300) I did all the surface prep and taping. My buddy’s neighbor, Dan, sprayed the primer and surfacer, and I took it home and spent a week blocking it. Then I brought it back to Dan’s shop, re-prepped and re-taped everything and he shot base/clear on the insides of the doors and jams that evening. The next day he sealed the outside and sprayed it with base/clear. My buddy wanted some painting experience (he’s working on a ’65 Mustang Fastback) so he stayed in the booth the whole time and shot the basecoat on one side of the bed. Dan also gave me a lesson on Bondo and a dolly/slaphammer when he started repairs on one side of the bed for me. He also pulled a dent on the door (no Bondo needed after he finished that spot.) He charged me $450 for his spray hours in the booth. So the paint job cost more than what I budgeted and far better from the paint job I had originally anticipated!
Just an Average Joe ![]() ‘68 GMC 307 3spd – My dad's original truck 310,000 miles Last edited by SacramentoJoe; 05-31-2007 at 05:48 PM. Reason: gotta add a picture |
#25 |
Hell, the paint jobs on our bikes start at $6k... I had a scuff n shoot done with paint I supplied for $2500.
My painter and I are going to redo the whole thing this winter, and he told me to bring 17k cash, and I had to help do the work takin it apart and getting it ready... If I could get my truck painted for 5k, id be stoked! Will
1970 C10, shortened long bed, Alum Headed full roller 383 (with Victor, 750DP, stainless rockers, behive springs, CNC ported heads) TCI SSF 700R4, 4.10 Posi, Bagged on C-Notch and 2.5 spindles. Air Cond, black out tint, satin black paint, custom interior, rolling low and not so slow... |
